    SUB-D Extrusion Problems SU 2016
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    2 Posts 2 Posters 8.3k Views 2 Watching
    • A
      alvarosu
      Hi, this is my first post and maybe someone could help me.
      After installing SUB-D the extrusion doesn't stop at the height I type after pressing Enter.
      Enter is not recognized, it only works manually with the mouse click but not at the height typed.
      The parametric extrusion works on SU 2017 but I need the SU 2016 as I'm using other plugins.
      Do you know what can I do to solve the problem? Thanks very much.
      • thomthomT
        Are you talking about the custom Push/Pull tool that SUbD provides? Which version of SUbD are you using and what OS?
        Do I understand it correctly that SU2017 works as you expect, but SU2016 doesn't?
