SUB-D Extrusion Problems SU 2016
Hi, this is my first post and maybe someone could help me.
After installing SUB-D the extrusion doesn't stop at the height I type after pressing Enter.
Enter is not recognized, it only works manually with the mouse click but not at the height typed.
The parametric extrusion works on SU 2017 but I need the SU 2016 as I'm using other plugins.
Do you know what can I do to solve the problem? Thanks very much.
Are you talking about the custom Push/Pull tool that SUbD provides? Which version of SUbD are you using and what OS?
Do I understand it correctly that SU2017 works as you expect, but SU2016 doesn't?
