Plugin lines to profiles
Hi All,
i'm new to sketchUcation and i'm wondering if any of you know about a plugin that can do the following:
Suppose i want to draw Zaha Hadid's building in Antwerp just with lines that are transformed into windows with glass... wouldn't that be awesome!
Drawing lines that are connected forming surfaces to profiles (square tubes).
Purpose: to draw dome-like structures with triangles and squares made with lines to transform into window-profiles.
looking forward to your responses.
Peter
Didier's Line to Tube plugin...
TIG extrusion tools.
Use the free S4u Make Face byhdpvto create the glass in conjunction with one of the above mentioned. See attached video.
http://extensions.sketchup.com/en/content/s4u-make-face
thx, but I found that one only making round tubes, not square ones I need for my windows.
Didier Bur Lines to tubes Plugin make also square tube!
Just change number segments' section! So Precision = 4!
And if you want Toblerone's boxes enter Precision = 3!
With your input, this post could be even better ๐
Register LoginAdvertisement
