    Plugin lines to profiles
    extensions
    7 Posts 6 Posters 4.3k Views 6 Watching
      petervanhove
      Hi All,
      i'm new to sketchUcation and i'm wondering if any of you know about a plugin that can do the following:
      Suppose i want to draw Zaha Hadid's building in Antwerp just with lines that are transformed into windows with glass... wouldn't that be awesome!
      Drawing lines that are connected forming surfaces to profiles (square tubes).
      Purpose: to draw dome-like structures with triangles and squares made with lines to transform into window-profiles.
      https://static.dezeen.com/uploads/2016/09/port-house-antwerp-zaha-hadid-architects-hufton-and-crow_dezeen_2364_col_3-852x1341.jpg
      looking forward to your responses.
      Peter
      without the glitches on the end, just used the follow me tool as a sketch for the idea
        Didier's Line to Tube plugin...
        404 Not Found
        (sketchucation.com)
        • gillesG Offline
          gilles
          TIG extrusion tools.
          404 Not Found
          (sketchucation.com)
            rodman100
            Use the free S4u Make Face byhdpvto create the glass in conjunction with one of the above mentioned. See attached video.
            http://extensions.sketchup.com/en/content/s4u-make-face
            window-profiles.avi
              petervanhove
              404 Not Found
              (sketchucation.com)
              thx, but I found that one only making round tubes, not square ones I need for my windows.
              • srxS Offline
                srx
                404 Not Found
                (sketchucation.com)
                www.saurus.rs
                  Didier Bur Lines to tubes Plugin make also square tube! ๐Ÿค“
                  Just change number segments' section! So Precision = 4! ๐Ÿ˜‰
                  And if you want Toblerone's boxes enter Precision = 3! ๐Ÿ˜„
