    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • gullfoG Offline
        gullfo
        wall structure using additional support for beam over door or window.![example steel framing for beam over door. you would adda stud on each edge of the steel column to support the top plates. but this is the idea. today when this arises, i just manually remove the members and add the needed assemblies.
        Glenn
        http://www.runnel.com
        • medeekM Offline
          medeek
          Very interesting. Let me see what I can do.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.7.2 - 10.13.2024
            • Fixed a critical bug with the in-wall column module.
            • Added the following additional Wide Flange (W14) beams to the beam module: W14X38, W14X43, W14X48, W14X53, W14X61, W14X68, W14X74, W14X82, W14X90, W14X99
            • Added the following additional Wide Flange (W16) beams to the beam module: W16X45, W16X50, W16X57, W16X67, W16X77, W16X89, W16X100
            • Enabled a wood grain and an end grain material for glulam beams within the beam module.
            • Enable additional built-in materials for "Custom" in-wall columns.
            • Added the following (27 - low poly) Simpson column bases to the post module: CB7_6, CB1212, CB1012, CB1010, CB812, CB810, CB718_7, CB718_6, CB718_4, CB612, CB610, CB88, CB86, CB68, CB64, CB48, CB46, CB9_105, CB9_75, CB9_9, CB9_6, CB7_105, CB7_75, CB7_9, CB6_7, CB5_45, CB5_6
            • Added the following (6 - low poly) Simpson column caps to the post module: CCQ84, CCQ86, CCQ94, CCQ96, CCQ98, CCQ106
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.7.2b - 10.14.2024
              • Added in the remainder of the commonly available wide flange beams (W4 thru W44).
              I think it comes to just a little over 250 different W flange beam profiles. However I'm sure there are some profiles I am missing or that are not as standard, if so let me know and I will add them in.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.7.3 - 10.14.2024
                • Added a duplicate post check to the regen module for post assemblies.
                • Added a duplicate beam check to the regen module for beam assemblies.
                • Added a duplicate stair check to the regen module for stair assemblies.
                • Added in the remainder of the commonly available wide flange beams (W4 thru W44) to the post module.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.7.5 - 10.23.2024
                  • Added the following (9 - low poly) Simpson post caps to the post module: LPC4_4, LPC4_6, LPC4_8, LPC6_4, LPC6_6, LPC6_8, PC4, PC6, PC8
                  • Added the following (10 - low poly) Simpson post bases to the post module: ECB88, ECB66, EPB66, EPB46, EPB44, MPB44, MPB66, MPB88, PPBF44, PPBF66
                  The post module now has 86 post caps and 65 post bases within its built-in library. I think I've modeled about 75% of the Simpson Strong-Tie's Wood Construction Connectors Catalog at this point.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I will be running a Thanksgiving promotion beginning Nov. 11th until Dec. 5th with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS24.
                    This will reduce the bundle price from $280.00 USD to $162.00 USD. This promo code does not apply to any of the extensions purchased separately. As part of this promotion a permanent license for the electrical plugin will be included upon request at no additional cost. The offer ends on Dec. 5th and no rain checks will issued thereafter.
                    design.medeek.com
                    I running this promotion a bit earlier this year to also coincide with the ongoing SketchUp Basecamp (Nov. 11-14, 2024):
                    https://3dbasecamp.sketchup.com/en
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 53: Multi-Landing Stairs (10:21)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Switching between landing and no-landing:
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.7.7 - 12.12.2024
                          • Added a "Calculated Parameters" section to the edit menu of the stair module.
                          • Added the ability to create L-Shape, U-Shape and Straight runs of stairs with landings.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 54 - Stairs with Landings (13:27 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              With each landing being configurable, its possible to mix and match some of the landings:
                              wall_su814_800.jpg wall_su815_800.jpg wall_su816_800.jpg wall_su817_800.jpg wall_su818_800.jpg wall_su819_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at double landing configurations with 2-step and 3-step L-winders:
                                wall_su820_800.jpg wall_su821_800.jpg wall_su822_800.jpg wall_su823_800.jpg wall_su824_800.jpg wall_su825_800.jpg wall_su826_800.jpg
                                design.medeek.com
                                gullfoG 1 Reply Last reply Reply Quote 0
                                • gullfoG Offline
                                  gullfo @medeek
                                  that looks like a lawsuit just waiting to happen lol 🙂
                                  Glenn
                                  • medeekM Offline
                                    medeek
                                    Tutorial 55 - Complex Stairs</a> (9:57 min.)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Since I've been focusing on updating the stair module the last week I've had quite a number of requests for various things. One request is the ability to flare out the bottom of the stairs. I can add in this functionality however to start with it would be very rudimentary (just a modification to the treads and risers as shown):
                                      I'm not entirely sure how one would go about in-fill framing the flared portion, nor do I think there is any established or standard way to do this, I could be wrong. Any thoughts or ideas in this regard? I should probably ask first if this is something that you would all want or even need.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at an inverted T-Shape staircase with a straight and a curved flare:
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Here is a quick study of the three types of tread extensions that are probably the most common. I can probably make this happen but it will have a number of new parameters in yet another sub-menu.
                                          With the half and full round, the riser simply follows the nosing dimension, however with the square cut extension the amount of the riser extension could be independent.
                                          For both the full and half round the radius of the curve is paramount but also the placement of the center of the curve in the Y direction (perpendicular to the stringers). The extension variable can be used for the Y-dir placement of the curve.
                                          The round nosing makes things a bit interesting but that can also be dealt with by breaking things down into a piecemeal modeling algorithm and then using some boolean addition of solids.
                                          The parameters shall be:
                                          Tread Extension Options:
                                          Extension Side: Both, Left, Right
                                          Extension Type: Square, Round, Half Round
                                          Tread Ext. Length: 10" etc... (this variable also sets Y placement of center of curve)
                                          Riser Ext. Length: 8" etc... (only applies to the square ext.)
                                          Extension Radius: 10" etc... (only applies to full or half round extension)
                                          I never get a day of rest, maybe after this update I'll move back to the Floor plugin...
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            If I enable some turn outs and volutes I will need to adjust for these but also I need to provide some additional parameters so one can fine tune the placement of the handrail and its termination:
                                            design.medeek.com
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 80
                                            • 81
                                            • 70 / 81
