    Roundhouse.
    17 Posts 6 Posters 4.4k Views 6 Watching
      A circular two floor dwelling with three bedrooms and one bathroom upstairs, library, kitchen, dining and living room downstairs.
      Dining to library/reading area entry and kitchen,
      • DanielD Offline
        Daniel
        It would be nice to see more, maybe even a floor plan. Unfortunately, that one image doesn't really convey the "round" design. You might want to also reconsider the lighting; the lights give it a very institutional feel (think 2x4 fluorescents in a lay-in ceiling grid), and seem at odds with the shapes of the spaces.
        My avatar is an anachronism.
        • pbacotP Offline
          Render's very realistic, except which seem like light leaks or flares in some places around the edge of the ceiling, which make it looks like it is floating above the walls.
            Thanks guys, looking into those points. Having a difficult time working out the best angles etc.
              Overview. WIP.
              Overview
              • pbacotP Offline
                Thanks for posting the plan!
                  I do not use plans, I do not have layout so everything develops organically.
                  • DanielD Offline
                    Daniel
                    I'm guessing you have the same problem I have in real life when I am trying to photograph small spaces - it's just impossible to fit everything in the frame. You might consider turning off some exterior walls so you can position the camera outside. Did you consider small, round recessed lights?
                      I have thought of those lights, round and recessed can be very effective, I just doodle until things fall into place. i also wondered about cutouts in the wall to make camera placement and viewing easier.
                      • pbacotP Offline
                        I mean the 3d plan. That's fine.
                        • Bryan KB Offline
                          Very nice!
                            Thanks Bryan.
                            • Bryan KB Offline
                              Looking forward to more.
                              • tademaT Offline
                                tadema
                                Wow, great render, model and design mike 👍
                                  Thanks John, I ran into a slight problem with textures causing the hdri background to be lost during render so it will take me a while to get back to that point. I am making something I would want to live in rather than a have generic plan to start from.
                                    mwm5053
                                    Looking good Mike. Nice idea about the round walls. Any ideas about how you could actually build one?
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                      There is only so much round in the house, I stuck with the 24 segments natively used in Sketchup. The paio doors will not work so will be changed to standard items. Few other problems and nothing that cannot be solved.
                                      Just wondered if you meant the structure. There are external pillars around the ground floor, four of them. Each floor level would have a steel skeleton with potentiall concrete block floors but the walls would be composite panels bolting together. The upper floor overhangs the ground floor by about 5 feet.
