    Roundhouse.
    17 Posts 6 Posters 4.8k Views 6 Watching
    • pbacotP
      Thanks for posting the plan!
        I do not use plans, I do not have layout so everything develops organically.
        • DanielD
          Daniel
          I'm guessing you have the same problem I have in real life when I am trying to photograph small spaces - it's just impossible to fit everything in the frame. You might consider turning off some exterior walls so you can position the camera outside. Did you consider small, round recessed lights?
          My avatar is an anachronism.
            I have thought of those lights, round and recessed can be very effective, I just doodle until things fall into place. i also wondered about cutouts in the wall to make camera placement and viewing easier.
            • pbacotP
              I mean the 3d plan. That's fine.
              • Bryan KB
                Very nice!
                  Thanks Bryan.
                  • Bryan KB
                    Looking forward to more.
                    • tademaT
                      tadema
                      Wow, great render, model and design mike 👍
                        Thanks John, I ran into a slight problem with textures causing the hdri background to be lost during render so it will take me a while to get back to that point. I am making something I would want to live in rather than a have generic plan to start from.
                          mwm5053
                          Looking good Mike. Nice idea about the round walls. Any ideas about how you could actually build one?
                          2011 iMac
                          SU 2015 Pro, 2017 Make
                          V2 Twilight
                          macOS Sierra 10.12.5
                            There is only so much round in the house, I stuck with the 24 segments natively used in Sketchup. The paio doors will not work so will be changed to standard items. Few other problems and nothing that cannot be solved.
                            Just wondered if you meant the structure. There are external pillars around the ground floor, four of them. Each floor level would have a steel skeleton with potentiall concrete block floors but the walls would be composite panels bolting together. The upper floor overhangs the ground floor by about 5 feet.
