    Complex surface divide into regular quads
    15 Posts 4 Posters 2.5k Views 4 Watching
    • M
      Mike91
      Hello, I'm writing for a problem I'm having trying to make a space structure.
      I can't seem to find a solution so here is the problem:
      I'm trying to make a space truss similar to the one in the last image, in order to do that I'd need to have a surface made of regular quads (or at least similar to each other as they can be) in order to than use the plugin that converts lines into tubes. The problem is that the surface I have is basically generated from to arcs and another arc which is the direction line. I can do the surface with the extrude to rails plugin but it isn't made of quads.
      So my question is, is there a way to make a complex surface as the one i'm trying to make, and have it made of regular quads or at least similar to each other in dimensions? The idea is to have the surface divide into equal parts.
      Thanks for helping!
      Similar structure
      Walls I need to cover with the space structure
      Curved surface made with extrusion tools (extrude by rails)
      Walls with the surface I need to have divide into equal quads
      Lines from which I generated the surface (2 arcs and an arch for direction)
        Without a SKP file to play with it is harder to help but I would use CurviLoft by Fredo to skin the profiles and rails...
        then run the tubing plugin...
        • M
          Mike91
          Thank you for your answer, I've tried with curviloft but can't seem to make it work. Maybe because I've never used it and didn't understand all the commands from the tutorial.
          Here is the .skp file in sketchup8
          Space truss.skp
            Your profiles are very dense.
            Maybe adjust them to reflect the final form you need....
            Space truss.skp
              Sorry, here's a v8 version of the file...
              Space truss-v8.skp
              • M
                Mike91
                Thank you again for helping.
                The problem is that i need squares of about 1 meter x 1 meter and I can't seem to get that with curviloft.
                Plus with curviloft i get that circle on the top as you've made.
                I've also tried to make a plane with the 1x1 meter grid and then curved it so that it would fit my surface but I wasn't able to do it.
                • gillesG
                  gilles
                  This could be a first step:
                  slicer5 from TIG in extension store.
                    Gilles just svaed the day. Nice approach!
                    • gillesG
                      gilles
                      Lot of work after this to make a decent model…
                      • M
                        Mike91
                        Thank you very much! I'll download and try tomorrow. It's definitely a lot of work but I need it in order to make an architecture collage on photoshop to show a view of the interior and exterior.
                        • M
                          Mike91
                          I've tried your method and I now have the surface with mostly regular quads.
                          I now have to make "pyramids" on top of them in order to have the final space truss to transform into tubes.
                          I've started to do that on a face but I'm struggling to get the vertical line to the single face in order to than make the four lines that reach the four vertices in order to make the pyramid. Also is there a way to automatically transform all those quad faces into pyramids with a 1 meters by 1 meters base(the one already existing in the mesh) and a 0.5 meters height? I've tried the s4u to component but can't make it work...
                          Thank you very much for helping!
                          Space truss.skp
                          • gillesG
                            gilles
                            Ok, let's have a more simple workflow:
                            Find the center of the arc
                            create a comp and copy/array
                            copy/array on the other side
                            erase unwanted
                            Spacetruss.skp
                            • M
                              Mike91
                              Wow! I can't thank you enough, I didn't know sketchup could do something that complex!
                              • gillesG
                                gilles
                                The model is far from perfect, so do one by yourself if you want good results.
                                  SketchUp can make anything! (or near... πŸ’š
                                  You must just training! πŸ˜‰
                                  Making of
                                  By Karanak
                                  http://orig02.deviantart.net/9426/f/2012/076/4/e/maelstrom_by_karanak-d4t0rdy.jpg
