    Complex surface divide into regular quads
    15 Posts 4 Posters 2.6k Views 4 Watching
      Sorry, here's a v8 version of the file...
      Space truss-v8.skp
        Mike91
        Thank you again for helping.
        The problem is that i need squares of about 1 meter x 1 meter and I can't seem to get that with curviloft.
        Plus with curviloft i get that circle on the top as you've made.
        I've also tried to make a plane with the 1x1 meter grid and then curved it so that it would fit my surface but I wasn't able to do it.
        • gillesG
          gilles
          This could be a first step:
          slicer5 from TIG in extension store.
            Gilles just svaed the day. Nice approach!
            • gillesG
              gilles
              Lot of work after this to make a decent model…
                Mike91
                Thank you very much! I'll download and try tomorrow. It's definitely a lot of work but I need it in order to make an architecture collage on photoshop to show a view of the interior and exterior.
                  Mike91
                  I've tried your method and I now have the surface with mostly regular quads.
                  I now have to make "pyramids" on top of them in order to have the final space truss to transform into tubes.
                  I've started to do that on a face but I'm struggling to get the vertical line to the single face in order to than make the four lines that reach the four vertices in order to make the pyramid. Also is there a way to automatically transform all those quad faces into pyramids with a 1 meters by 1 meters base(the one already existing in the mesh) and a 0.5 meters height? I've tried the s4u to component but can't make it work...
                  Thank you very much for helping!
                  Space truss.skp
                  • gillesG
                    gilles
                    Ok, let's have a more simple workflow:
                    Find the center of the arc
                    create a comp and copy/array
                    copy/array on the other side
                    erase unwanted
                    Spacetruss.skp
                      Mike91
                      Wow! I can't thank you enough, I didn't know sketchup could do something that complex!
                      • gillesG
                        gilles
                        The model is far from perfect, so do one by yourself if you want good results.
                          SketchUp can make anything! (or near... πŸ’š
                          You must just training! πŸ˜‰
                          Making of
                          By Karanak
                          http://orig02.deviantart.net/9426/f/2012/076/4/e/maelstrom_by_karanak-d4t0rdy.jpg
