    Displacment corner problem
    renderpluginsextensions
    9 Posts 4 Posters 1.5k Views 4 Watching
    • M
      marwan2003
      hi dears
      kindly, i have problem when using displacment on an surface there is an offset appear on the corner like below image (on left ), please your advice?
      http://www.cgpack.com/content/uploads/2014/01/d03.jpg
        What rendering application are you using? Would you share the SKP file, please? It'll make it possible to diagnose the real problem.
        By the way, this is not a SketchUp bug so I moved your post.
        • jujuJ
          juju
          use smoove on the corners
          • M
            marwan2003
            please can you share with me video showing how to use smoove with corner?
            • M
              marwan2003
              im using vray .
              and i dont know how to share the skp file in this website ?
                @marwan2003 said:
                im using vray .
                It would have been useful if you'd told us you're using Vray in your first post. I moved this to the right forum.
                Attach the SKP file using the Upload attachment below the message window.
                • tademaT
                  tadema
                  Make sure your geometry is grouped and check box is ticked.
                  John
                  • M
                    marwan2003
                    [attachment=1:l2dhcx8m]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:l2dhcx8m]
                    John
                    my geometry is grouped and the check box you mention ticked.
                    you can find the skp file in attach.
                    thanks for your support
                    Untitled.skp
                    • M
                      marwan2003
                      please find my skp file in attach
                      Untitled.skp
