    Displacment corner problem
    renderpluginsextensions
    9 Posts 4 Posters 1.4k Views 4 Watching
      marwan2003
      hi dears
      kindly, i have problem when using displacment on an surface there is an offset appear on the corner like below image (on left ), please your advice?
      http://www.cgpack.com/content/uploads/2014/01/d03.jpg
        What rendering application are you using? Would you share the SKP file, please? It'll make it possible to diagnose the real problem.
        By the way, this is not a SketchUp bug so I moved your post.
        • jujuJ Offline
          juju
          use smoove on the corners
            marwan2003
            please can you share with me video showing how to use smoove with corner?
              marwan2003
              im using vray .
              and i dont know how to share the skp file in this website ?
                @marwan2003 said:
                im using vray .
                It would have been useful if you'd told us you're using Vray in your first post. I moved this to the right forum.
                Attach the SKP file using the Upload attachment below the message window.
                • tademaT Offline
                  tadema
                  Make sure your geometry is grouped and check box is ticked.
                  John
                    marwan2003
                    [attachment=1:l2dhcx8m]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:l2dhcx8m]
                    John
                    my geometry is grouped and the check box you mention ticked.
                    you can find the skp file in attach.
                    thanks for your support
                    Untitled.skp
                      marwan2003
                      please find my skp file in attach
                      Untitled.skp
