    Exporting 2D graphic in dwg > doesn't create the file
    5 Posts 5 Posters 7.9k Views 5 Watching
    • M
      mdg44
      Hi all,
      When trying to export a 2D graphic, using file > export > 2d graphic and choosing dwg file format and the location, Sketchup acts like it does when exporting to any other file format but when I go to the folder, the file isn't actually there.
      I can export to pdf to that same folder, but when doing so to dwg the file doesn't appear.
      I am using Sketchup Pro 2017 on a Macbook pro with OSX 10.11.6 installed. The same thing used to happen back when I was using Sketchup Pro 2015. Both are licensed versions.
      • John SayersJ
        John Sayers
        works for me in windows version
        • S
          slbaumgartner
          It works for me on mid-2012 MBP retina, SU 2017, OS X 10.12.3.
          • TIGT
            Since we don't have your specific SKP file...
            Does it contain some geometry - lines/faces etc - which could get exported into a DWG ?
            Could you attach a simple SKP example that fails to make a DWG etc...
            • JQLJ
              JQL
              Or are you trying to export a section without an active section in the model
              www.casca.pt
              Visit us on facebook!
