    Follow Me and Rotate Plugin not working
    10 Posts 5 Posters 3.5k Views 5 Watching
    • D
      dkressjr
      Hello All,
      I recently installed the follow me and rotate plugin through the sketchucation plugin installer. The plugin does not work. Every time i load sketchup it a diolouge pop up that says, Error: SketchUp:1:in eval'. Then when i try to use the plugin, following all the instructions i get this message in the ruby console box. Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)> c:/users/david kress jr/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in add'
      c:/users/david kress jr/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull' c:/users/david kress jr/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>'
      SketchUp:1:in `call'
      please help
        Maybe I try installing it again. I just installed it a few minutes ago and restarted SketchUp. No error messages and it works as advertised.
        • F
          frycakf
          Same problem here
            @frycakf said:
            Same problem here
            How did you go about installing it?
            • soloS
              solo
              Cannot get this to work with SU 2017, no dialogue appears.
              http://www.solos-art.com
                It hasn't been updated for years so it's not surprising that it doesn't work.
                • soloS
                  solo
                  I'm having a blond moment, I have not used these tools in a while and I need to extrude a shape vertically like a corkscrew and cannot figure out why it's so difficult.
                    This one hasn't been updated for years either.
                    Maybe Eneroth Upright Extruder would do the job for you. Get it in the Extension Warehouse.
                    • soloS
                      solo
                      Tried that without success, I used SU8 and 'follow and rotate' worked for my needs. Thanks
                      • TIGT
                        This tool fails in v2017 [like several others].
                        It also has several longstanding coding deficiencies, which would require wide-ranging recoding...
                        Fixing it won't be an easy task... 😞
