    Extrusion Tools.
    extensions
    5 Posts 3 Posters 3.2k Views 3 Watching
      I have found the tools do not work in Sketchup 2017, when I try to use edges by rails I get some kind of pick points but no surface. In Sketchup 2016 no problems and scale is NOT a factor.
      Failed extrusion.
        Still experiencing this issue, is it just the newer Sketchup variety?
        • TIGT Online
          Sorry I missed your earlier post.
          SketchUp v2017 broke several extensions, because it [unexpectedly] changed the way entity ID s are handled etc.
          One of these plugins includes some of the Extrusion Tools.
          I am working on their fixes.
          I now have most of them working again.
          But I still need to tweak the last few and beta-test the set...
          I hope to have a v2017 version published soonest...
          πŸ€“
          PS: If you or anyone else gets problems in v2017 with ANY plugin, which has worked OK in v2016, then please post reports in that Plugin's thread - it's most likely to be spotted there - and hopefully fixed...
            I'm sorry I missed your reply too, thanks for the heads up, the plug ins you and others produce make Sketchup easier and better. Thank you.
            • E Offline
              EWongsta
              Will there be a fix soon for for SketchUp 2017 version soon? This plugin is awesome, but it is unfortunate that it is still not working with 2017 yet. Thanks.
