Plugin Sheet Metal Bender by SDMITCH
SAM SDMITCH just realized a new plugin: SHEETMETAL BENDER
[highlight=#ffff40:16r56cnl]i can be download here :[/highlight:16r56cnl]
http://sdmitch.blogspot.fr/2 parameters are possible: Inter Radius and angular rotation.
The first click selects the face to be extruded
the 2nd click indicates the line serving as a pivot
The Shift key is used to reverse the direction of extrusion.
The tab key is used to validate a value in the parameter table.
A left click valid the extrusion.
A right click exit the plugin.Some notes:
Do not work on a group (explode before use)
A one-time pressing Ctrl , before a Push Pull ,will keep the generators of the first
surface.
A final cleaning was done to hide unnecessary edges.
Creating a shortcut is possible to call the pluginPlease take a look on the next pictures
( the first 3 pictures are animated GIF )
The animation number 3 was made with the new Fredo6's plugin ; ANIMATOR
Thank you to Sam SDMITCH and Fredo6 for their work and their availability.
Little reminder :
This plugin help for drawing sheetmetal part .
Unfolding is not planned , this type of work requiring specific software depending
of the materials , the direction of the fibers, the working temperature, material
aging , machine park ...
I would say ,the customer make a drawing and Maker do!Chri
a +
Sheet Metal Bender is now posted to my blog.
Any and all questions on use and operation should be directed to chri.
Many thanks Sam
SAM has done a new release .
the plugin can be download here :
http://sdmitch.blogspot.fr/Chri
Seems select the 3 faces Then Curviloft are more natural! (and more easy to select)
And useful if you want make some extrudre from them after in the space!
About Sheet Metal Bender inside 2017 I have not the Window's parameters
but open trying Internet site and an offer temp windows save!
How resolve that and have you the same ?
Maybe because plugin is not certified ?...Plugin itself works with default regulates!
http://sdmitch.blogspot.fr/Clicking on the "plugin" does an "unzip" of the rbz, but does not download it or make it otherwise available
[attachment=0:1j8n1nyd]<!-- ia0 -->sm.PNG<!-- ia0 -->[/attachment:1j8n1nyd]
hit the download icon
or click like the picture
then download
I get this when trying in 2017. I doubt it is the fault of the extension but probably something weird with my setup.
I have the same as Jim! ( 2017) : works fine in 2016!
It's surrely about the Open window's parameters!
We can't see it!
Certified plugin ?
Maybe it's about IE 11 ?...but I don't success to find what I must do!
The plugin works fine with default parameters!
I also posted the issue on the official forum. The more eye the better.
I took a few minutes this morning to make it work with 2017 because I was curious. I will finish it this afternoon and send it to Sam if he is interested or unless he beats me to it.
http://forums.sketchup.com/t/2017-is-webdialog-set-html-broke/33544/1
Can this still be downloaded somewhere? its exactly what i need but there is nothing on the link provided..
Unfortunately, Sam has removed all his plugins for download because of bogus copyright problems he had with another plugin (Floor Generator-search the forum).
Other than individual user copies, there are no other remaining (legitimate) download sites for his plugins.
That is really sad! is there any other plugins that are similar to this?
It's not difficult to model sheet metal parts with native tools. If I really felt I needed to use an extension for it, I would use Radial Bending in FredoScale.
You could also model the sheet metal as a single surface and then use Fredo6's Joint Push/Pull to give it thickness.
Or True Bend By Thomthom
Thanks guys, really appreciate it. The fredo scale radial bend does the trick.
A revised and working version can be downloaded HERE
Register LoginAdvertisement
