    Plugin Sheet Metal Bender by SDMITCH
    20 Posts 10 Posters 11.9k Views 10 Watching
    • jujuJ Offline
      juju
      @bob james said:
      SAM has done a new release .
      the plugin can be download here :
      http://sdmitch.blogspot.fr/
      Clicking on the "plugin" does an "unzip" of the rbz, but does not download it or make it otherwise available
      [attachment=0:1j8n1nyd]<!-- ia0 -->sm.PNG<!-- ia0 -->[/attachment:1j8n1nyd]
      hit the download icon
      • chriC Offline
        chri
        or click like the picture
        then download
        • Bob JamesB Offline
          Bob James
          Thank you, I didn't see the arrow.
            Jim
            I get this when trying in 2017. I doubt it is the fault of the extension but probably something weird with my setup.
              I have the same as Jim! ( 2017) : works fine in 2016!
              It's surrely about the Open window's parameters!
              We can't see it!
              Certified plugin ?
              Maybe it's about IE 11 ?...but I don't success to find what I must do! 😲
              The plugin works fine with default parameters!
                Jim
                I also posted the issue on the official forum. The more eye the better.
                I took a few minutes this morning to make it work with 2017 because I was curious. I will finish it this afternoon and send it to Sam if he is interested or unless he beats me to it.
                Site Not Found - Discourse
                (forums.sketchup.com)
                • E Offline
                  ErikJax
                  Can this still be downloaded somewhere? its exactly what i need but there is nothing on the link provided.. πŸ˜•
                    db11
                    Unfortunately, Sam has removed all his plugins for download because of bogus copyright problems he had with another plugin (Floor Generator-search the forum).
                    Other than individual user copies, there are no other remaining (legitimate) download sites for his plugins.
                    • E Offline
                      ErikJax
                      That is really sad! is there any other plugins that are similar to this?
                        It's not difficult to model sheet metal parts with native tools. If I really felt I needed to use an extension for it, I would use Radial Bending in FredoScale.
                        You could also model the sheet metal as a single surface and then use Fredo6's Joint Push/Pull to give it thickness.
                          Or True Bend By Thomthom πŸ˜‰
                          • E Offline
                            ErikJax
                            Thanks guys, really appreciate it. The fredo scale radial bend does the trick.
                            • judedouchJ Offline
                              judedouch
                              A revised and working version can be downloaded HERE
