    Plugin Sheet Metal Bender by SDMITCH
    20 Posts 10 Posters 11.8k Views 10 Watching
    • chriC Offline
      chri
      Example with Sheet Metal Bender and curviloft .
      Chri
      COIN BOULE.skp
        Seems select the 3 faces Then Curviloft are more natural! (and more easy to select)
        And useful if you want make some extrudre from them after in the space! πŸ˜‰
          About Sheet Metal Bender inside 2017 I have not the Window's parameters
          but open trying Internet site and an offer temp windows save!
          How resolve that and have you the same ?
          Maybe because plugin is not certified ?...
          Plugin itself works with default regulates!
          • Bob JamesB Offline
            Bob James
            SAM has done a new release .
            the plugin can be download here :
            http://sdmitch.blogspot.fr/
            Clicking on the "plugin" does an "unzip" of the rbz, but does not download it or make it otherwise available
            • jujuJ Offline
              juju
              [attachment=0:1j8n1nyd]<!-- ia0 -->sm.PNG<!-- ia0 -->[/attachment:1j8n1nyd]
              hit the download icon
              • chriC Offline
                chri
                or click like the picture
                then download
                  Bob James
                  Thank you, I didn't see the arrow.
                    Jim
                    I get this when trying in 2017. I doubt it is the fault of the extension but probably something weird with my setup.
                      I have the same as Jim! ( 2017) : works fine in 2016!
                      It's surrely about the Open window's parameters!
                      We can't see it!
                      Certified plugin ?
                      Maybe it's about IE 11 ?...but I don't success to find what I must do! 😲
                      The plugin works fine with default parameters!
                        Jim
                        I also posted the issue on the official forum. The more eye the better.
                        I took a few minutes this morning to make it work with 2017 because I was curious. I will finish it this afternoon and send it to Sam if he is interested or unless he beats me to it.
                        [2017] Is WebDialog.set_html broke?
                        I wanted to try out Sam’s Sheet Metal Bender extension but the WebDialog does not open the temp file. Instead i get these dialogs. It works in 2016. Any ideas?
                        SketchUp Community (forums.sketchup.com)
                        • E Offline
                          ErikJax
                          Can this still be downloaded somewhere? its exactly what i need but there is nothing on the link provided.. πŸ˜•
                            db11
                            Unfortunately, Sam has removed all his plugins for download because of bogus copyright problems he had with another plugin (Floor Generator-search the forum).
                            Other than individual user copies, there are no other remaining (legitimate) download sites for his plugins.
                            • E Offline
                              ErikJax
                              That is really sad! is there any other plugins that are similar to this?
                                It's not difficult to model sheet metal parts with native tools. If I really felt I needed to use an extension for it, I would use Radial Bending in FredoScale.
                                You could also model the sheet metal as a single surface and then use Fredo6's Joint Push/Pull to give it thickness.
                                  Or True Bend By Thomthom πŸ˜‰
                                  • E Offline
                                    ErikJax
                                    Thanks guys, really appreciate it. The fredo scale radial bend does the trick.
                                    • judedouchJ Offline
                                      judedouch
                                      A revised and working version can be downloaded HERE
