    Vray 3.4 Public Beta is Live
    renderpluginsextensions
    28 Posts 19 Posters 11.9k Views 19 Watching
      rv1974
      V on 'Use local subdivs', but it's a bad practice- the beauty of v.3.4 is ability to control the quality in a globalmanner.
      • V Offline
        vigge50
        @tedvitale_cg said:
        @vigge50 said:
        Really nice function, thanks for integrate it. Have you any plans or tips on programs to link several panoramas together so you can easy swish between panoramas?
        No plan on creating anything like that but I would go check out IrisVR's Scope App, I think it will be a good start for what you are looking for!
        That app worked for a month but then the trail version ended they now want $40/month to upload your image wish I think is way to mush, any other tip of apps that you can use or do I just have to except that I need to pay a lot to see my panoramas as VR?
        • X Offline
          xone
          I'm checking out the latest release but I can't find the "Flat Normal" option for VrayFur anywhere... It's been mentioned in Vray documentation under LOD settings but I don't see that option there, why?
          • H Offline
            humptyhumps
            Anyone having problems with V-Ray 3.4 Beta for SketchUp Pro 2016 where the scene does not render or even pop open a frame buffer when render buttons are hit. I have been trying to render a 6:1 Stereoscopic render for use with Google Cardboard. I installed V-Ray 3.4 Beta and the new License Server. I tested it with the opening scene in SketchUp and I can render 6:1 stereo format. However, when I open my SketchUp model and hit the 6:1 render button, or any other render button, it does not work. It doesn't even open the frame buffer window. In the command window at the bottom left of the SketchUp window I can see it initializes the scene but it doesn't get past "V-Ray Bootstrap: Building scene". Any help is appreciated. Thanks.
            • I Offline
              Isarescu
              @humptyhumps: make sure "production render mode" is selected!
                lvm333
                Hi!! I don't know what happened? my license expired, but the Chaos Group extended it to me until the end of this month. It turns out that reinstalling vray3.40 beta and now aparace this.
                Before I thought it was a bug in the program so I reinstalled vray 3.40 beta and now tells me all this and nothing works.
                7-Zip (a) [64] 15.14 : Copyright (c) 1999-2015 Igor Pavlov : 2015-12-31
                Scanning the drive for archives:
                1 file, 51336790 bytes (49 MiB)
                Extracting archive: C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\vrayappsdk\appsdk-win-1.8.3-vray3.40.4-20161026-beta.7z
                Path = C:\Program Files\Chaos Group\V-Ray\V-Ray 3.4 for SketchUp\extension\vrayappsdk\appsdk-win-1.8.3-vray3.40.4-20161026-beta.7z
                Type = 7z
                Physical Size = 51336790
                Headers Size = 2177
                Method = LZMA:24
                Solid = +
                Blocks = 1
                Everything is Ok
                Folders: 1
                Files: 108
                Compressed: 51336790
                Automatic installation was successful!
                Error loading logtext.dll.
                *** ServiceExe (startup) 1.0.5 - built 2010-10-01 13:09:35 ***
                OpenService failed - 'El servicio especificado no existe como servicio instalado. (0x424)'
                Path of executable: C:\Program Files\Chaos Group\V-Ray Swarm
                Service start type is 'Automatic'.
                Installing service 'vrswrm-service' as 'V-Ray Swarm'...
                Service 'V-Ray Swarm' installed.
                Starting service 'V-Ray Swarm'...
                Start pending for 'V-Ray Swarm'...
                Waiting...
                Waiting...
                Result of starting service 'V-Ray Swarm': Success.
                • P Offline
                  peerman
                  I think you need to install the trial version. The beta is closed now so that's why the license probably doesn't work anymore..
                  Best,
                  Peter
                  iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                    artsandcrafts
                    Yeah, that issue is my biggest problem in these days. And If there is any solution for that it will be great. In my model that phases take almost 1 hour or more and sometimes it causes to bugsplat... 😞 I couldn't take 8 rendering in a week becaue of that problem...
                    • 2 / 2
