    I need a plugin for random replacement
    14 Posts 6 Posters 1.3k Views 6 Watching
    • EdsonE Offline
      Edson
      what I want is this: on the facade of a building I want to show some windows open, some closed and some half-closed. for that purpose I created 3 similar components. now I want to distribute them randomly on the facade. but how?
      do you know of any plugins that would do that? there used to be one but I cannot find it.
      thanks for any help.
      http://www.mahfuz.arq.br
      • BoxB Offline
        You could use Tig's Random Select, and Replace Selection from the component dialog. http://sketchucation.com/pluginstore?pln=RandomSelect
        • sdmitchS Offline
          sdmitch
          "Component Replacement" plugin found on my blog may be of some help.
          http://sdmitch.blogspot.com/
            Of course you will have same result with taken Source as
            5 Object A, 2 objects B, 1 Object C ! πŸ’š
            So some more speedy and less heavy! πŸ€“
            My favorite versatile plugin! 😎 πŸ‘
              Sure with the Sdmitch one you can make that in one pass! 😎
              For make different pourcentage just create different familly
              of your Source Objects!
              For example
              a line of 50 object A
              A line of 20 Object B
              A line of 10 object C
              Like this you will have 50 % of object A
              20 % of object B
              10 % of object C
              Objects Target can be a simple cube! πŸ˜„
                rv1974
                The right, headache-free way to do it (preferably with shortcuts):
                1. Get definition*
                2. TIG's random select
                3. Apply definition*
                *- http://www.smustard.com/script/ApplyTo
                • EdsonE Offline
                  Edson
                  I thank you all for the help. I will surely check your suggestions.
                  I am almost sure that I used to do what I want in the past using some easy-to-use extension, something along the lines of Chris Fullmer's Random Painter.
                  best regards.
                  • JQLJ Offline
                    JQL
                    And does any of you know of a random component/group painter?
                    Select a lot of instances of the same component and a list of materials and randomly apply those materials to the components.
                    There's a Random painter that randomizes paint on faces but I was thinking about randomizing the material of component instances.
                    www.casca.pt
                    Visit us on facebook!
                      Sdmitch has made A color random replacement : ask him the same for textures! πŸ˜‰
                      • JQLJ Offline
                        JQL
                        Hi Mitch... πŸ˜„
                        www.casca.pt
                          Else Tig has made a Texture Randomizer πŸ˜‰
                          • JQLJ Offline
                            JQL
                            It's for faces, not components, I believe.
                            www.casca.pt
                            • JQLJ Offline
                              JQL
                              Really...? Thanks Pilou!
                              www.casca.pt
                                Sure !
                                For randomize all paramaters of a same texture! (Works also for Components & Groups)
                                But you can select several different textures on the same time! πŸ˜‰
                                They will have same variation of parameters!
                                (Different sizes of boxes is just perspective effect ! )
