    I need a plugin for random replacement
    14 Posts 6 Posters 1.4k Views 6 Watching
      Sure with the Sdmitch one you can make that in one pass! 😎
      For make different pourcentage just create different familly
      of your Source Objects!
      For example
      a line of 50 object A
      A line of 20 Object B
      A line of 10 object C
      Like this you will have 50 % of object A
      20 % of object B
      10 % of object C
      Objects Target can be a simple cube! πŸ˜„
        rv1974
        The right, headache-free way to do it (preferably with shortcuts):
        1. Get definition*
        2. TIG's random select
        3. Apply definition*
        *- http://www.smustard.com/script/ApplyTo
        • EdsonE Offline
          Edson
          I thank you all for the help. I will surely check your suggestions.
          I am almost sure that I used to do what I want in the past using some easy-to-use extension, something along the lines of Chris Fullmer's Random Painter.
          best regards.
          http://www.mahfuz.arq.br
          • JQLJ Offline
            JQL
            And does any of you know of a random component/group painter?
            Select a lot of instances of the same component and a list of materials and randomly apply those materials to the components.
            There's a Random painter that randomizes paint on faces but I was thinking about randomizing the material of component instances.
            www.casca.pt
            Visit us on facebook!
              Sdmitch has made A color random replacement : ask him the same for textures! πŸ˜‰
              • JQLJ Offline
                JQL
                Hi Mitch... πŸ˜„
                www.casca.pt
                  Else Tig has made a Texture Randomizer πŸ˜‰
                  • JQLJ Offline
                    JQL
                    It's for faces, not components, I believe.
                    www.casca.pt
                    • JQLJ Offline
                      JQL
                      Really...? Thanks Pilou!
                      www.casca.pt
                        Sure !
                        For randomize all paramaters of a same texture! (Works also for Components & Groups)
                        But you can select several different textures on the same time! πŸ˜‰
                        They will have same variation of parameters!
                        (Different sizes of boxes is just perspective effect ! )
