    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Finally, some more work by Jim Jeffries (JMJ Ohio)
    19 Posts 11 Posters 3.9k Views 11 Watching
    • hellnbakH Offline
      hellnbak
      Many of you will remember the mind-blowing work of Jim Jeffries (JMJ Ohio), first introduced to our forum here
      http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=40998%26amp;p=364289%26amp;hilit=check+out+this+amazing#p364289
      Well, he seemed to just disappear suddenly, so a few days ago I emailed him to find out where he had gone and what he's been up to, and he let me know that he, in his own words "was forced into retirement 2 years ago due to health issues. Took a nasty fall and suffered some head injuries". Sad news indeed, but he apparently hasn't let this slow down his incredible work with SU, as evidenced by a number of photos he was nice enough to include with his emails. He even went so far as to let me download some of the models, and graciously agreed when I asked if it was ok to post some of them here, so here goes.
      (Obviously the rendered images are his)
      First, his impeccable 2500hp '32 Altered
      Some screenshots of the model
      And the specs
      32 Altered specs
      NHRA TOP ALCOHOL ALTERED
      NHRA Class: AA/AM (Double A Altered Methanol with Lenco or BJ Transmission)
      Wheelbase: 124 inches
      Weight: 2,000 lbs
      Horsepower: approx. 2500
      Quarter Mile: 5.80 sec's @ 250 mph
      CONSTRUCTION
      Chassis: 4141 steel alloy round tubing - Tubing diameters and placement per NHRA spec's
      Suspension: None
      Front Rims / Tires: Billet Specialties 15 x 3.5 Comp 5 Series Spindle Mount
      Goodyear 24 x 3.5 x 15 Frontrunner
      Rear Rims / Tires: Billet Specialties 15 x 16 Comp 5 Series
      Goodyear 33 X 16 x 15 Eagle Slicks
      Brakes: Rear only - hand operated - Wilwood Calipers, Rotors, Master Cylinder and Reservoir
      Steering: Lowe Race Car Hardware Steering Box. Billet aluminum pitman arm, drag links, bellcrank, tie rods and spindle control arms
      Rearend: Narrowed and reinforced Ford 9 inch with 2.83 gears and Strange Engineering full floating axles
      Body: Carbon Fiber
      Fire Suppression: Fire Bottle
      Safety Equipment: Deist
      Data Acquisition: DataPak
      ENGINE
      Displacement: 508 cu. in's (4.30 bore x 4.375 stroke)
      Block: Robert Pond Motorsports (RPM) Aluminum Ford FE
      Crank shaft: Scat Billet 4.375 stroke
      Connecting Rods: Crower Billet 6.700 inch
      Pistons: Diamond - Ceramic coated domes, Graphite coated skirts
      Heads: Bill Coon aluminum
      Intake Manifold: Paul Munro
      Blower: Weiand 10/71
      Blower Drive: 1.3 : 1.0 overdrive
      Magneto: Cirello
      Injector: Lowe "Buzzard Catcher"
      Bellhousing: Trick Titanium
      Transmission: Lenco 2 speed with reverse unit
      Will post some more of his incredible work (and hopefully this post will draw him back to the forums)
        That is the product of a very talented artist, I hope he is able to return.
        • hellnbakH Offline
          hellnbak
          Yes, Mike. His talent is unbelievable, puts my best efforts to shame.
          • hellnbakH Offline
            hellnbak
            He also did some work with his original '32 Highboy.
            On display
            And the chassis in a very complete workshop
            Some screenshots of the model. Seems like every detail could stand on it's own.
            His renders of some of the details
            Still more to come
              Gorgeous details! ๐Ÿ˜Ž
              • andybotA Offline
                andybot
                wow!!!! Thanks for posting these. That's some very detailed modeling! Best wishes for Jim on his health issues.
                  Pardon me for saying so Steve but you are better than you give yourself credit for. In my book right up there on this forum at least. The integrity of your work makes your models must see from my perspective and your use of textures within sketchup, without a render engine/software is jaw dropping. You rock dood.
                  • hellnbakH Offline
                    hellnbak
                    His Harley Sportster
                    He commented that "I had a bike very similar to this in the early to mid 70's. Traded it for my first wife. Maybe the brain damage wasn't from this latest fall".
                    I asked Jim why the tach was rotated (I knew it couldn't be a mistake, that just doesn't happen with his models) and he replied that "It's a standard racing method for mounting gauges. Race drivers can't afford to take their eyes off the track long enough to study the gauges so they mount them such that the needle is straight up (12 o'clock) when the target value of what's being measured is reached. Desired oil pressure, water temperature, etc. The tach is rotated to indicate target gear shift point".
                    Just one more example of his quest for perfection.
                    Still more to come
                    • hellnbakH Offline
                      hellnbak
                      Thanks, Mike, but I'm not putting myself down, and It's not false modesty - I just recognize my limitations. I have studied the work of many modelers, and the simple fact is that they are capable of doing things that I cannot do. And, to me, Jim is the supreme example of this. His models are crisp and precise, every detail complete and accurate, clean, with no hint of sloppiness. Mine are "whatever works". They may look ok (from a distance), but I know how I modeled them. I do wish I could learn to use some of the incredible plugins used by others, but I know that ain't gonna happen. It used to frustrate and discourage me, but now I just accept that this is the way I'm going to use SU, and, hey, it probably doesn't mean the sun isn't going to come up tomorrow.
                      So I'm fine, and if do make a comment about how my work compares to someone else's, I'm not feeling sorry for myself, I'm just telling it like it is.
                      Bottom line is, if I wasn't having fun, I wouldn't be doing it, right? ๐Ÿ˜†
                      • hellnbakH Offline
                        hellnbak
                        1929 Ford Closed Cab Pickup with a 347 Ford engine
                        A WIP by Jim.
                        He noted that "Someone will comment that Ford did not produce a 347. That is technically correct. But Ford Racing and others offer this as a crate motor. It's a Boss 302 that is bored .030 over and has a +.400 stroke crank. It is used heavily in sportsman circle track racing and with the street rodding set. Works really well in an early 5.0 Mustang."
                        Some of Jim's renders of the engine
                        Wow, right?
                        • pbacotP Offline
                          Mindblowing and SWEET work.
                            db11
                            Incredible!
                            The engine renders are indistinguishable from actual photos, and the level of detail in all the models is remarkable.
                            • JMJOhioJ Offline
                              JMJOhio
                              I want to extend a special thanks to Steve for bringing me and my work back to the forum. The time and effort that he put into photo preparation, screen shots, narration and posting is deeply appreciated. Thanks Steve. ๐Ÿ‘
                              Mike, I don't consider myself a talented artist, more so a good technical illustrator. Machinery and product design was my primary occupation for many years. It's where I'm comfortable. I do a lot of research leading into and during a SketchUp project. I also use tons of construction geometry. For very complex parts I often create detailed multi view drawings in SU, turn them into groups or components and place them in the part to serve as templates. When it comes to organic surfaces, I fall on my face. If I can't describe something mathematically I start getting lost.
                              BTW, Steve's work is on my "A" list. I don't care if he stands on his head and works the keyboard with his toes to achieve it.
                              Thanks everyone, it's good to be back.
                              • pbacotP Offline
                                Glad to have you back, Jim. However it's approached, work like this comes from the heart.
                                • hellnbakH Offline
                                  hellnbak
                                  Welcome back, Jim. Good to see you here on the forums again. Thanks for the kind words, and I hope we will see much more of your amazing work here soon.
                                  • urgenU Offline
                                    urgen
                                    ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                    --pupil forever...------
                                    • Bryan KB Offline
                                      I'm pretty sure even my neighbors heard my jaw hitting the floor. ๐Ÿ˜ฎ
                                        Wow!
                                        • cheddaC Offline
                                          chedda
                                          Some serious hours work there impressive.
                                          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
