    FACEAREA("material") giving incorrect measurements
    4 Posts 2 Posters 3.9k Views 2 Watching
    • E
      ErikaKR
      I am new to using dynamic components, so there may be something obvious I am doing wrong,...?
      I am trying to produce a schedule of areas using dynamic components with a custom attribute area =FACEAREA("materialname")/2. However the results for the areas seem incorrect ( way out!). I am checking against the entity info results and with manual dimensions on the simpler rectangular areas.
      Does anybody have any ideas what I may be doing wrong? My drawing is set with millimetres as the units. Could it be a unit conversion issue? Although I have tried multiplying by 25.4 and that isn't giving me a correct answer either.
      Any ideas for things to check would be much appreciated.
      Thanks.
      • TIGT
        As far as I know DCs can be set up in either inches [Sketchup's default] or cm.
        I expect the area returned is in square inches ?
        If so, to turn that into sq mm you'll need to multiply it by 25.4*25.4 [it's 'square' no 'linear'...
        Or, if the DC is returning the area in sq cm, then try using *100 to change the sq cm into sq mm...
        • E
          ErikaKR
          Thank you TIG!
          It was my maths that was failing me. I failed to square. Though, I don't see why if Sketchup can give areas in the drawing set units (metric) in text and in entity info, it can't do it with facearea...?
          Thanks again.
          • TIGT
            DCs have no awareness of the Model Units, so you have to force it into using what units you want.
            DCs always default to inches unless told otherwise...
