    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Real world Wip. Glass sculptures.
    120 Posts 21 Posters 63.2k Views 21 Watching
      Cool glass mille-feuille ! ๐Ÿ˜Ž
      • Bryan KB Offline
        whoa! ๐Ÿ˜ฎ
        • BoxB Offline
          Here's a bit of an easter update.
          There was a bit of an issue with the transportation that caused a problem in one of the expansion layers of the second sculpture that produced a clouding effect right in front of the girl's face. As a result we needed to split the block and remove a 400 kilo section. Once separated we could clean the faces and redo the expansion layer.
          As this has all moved around 700km from the studio we had to find somewhere closer to work on it. Who would have thought you could split 400 kilos off a 3 ton block of glass in a tin shed in the back of beyond!
          A few images....
          Here she is with the light behind her before we start the repair. Only relevant because we never could see them like this in the studio.
          http://i155.photobucket.com/albums/s296/storeben/SU/20170413_112933_edit_1492349420726.jpg
          This is the block split into 2 sections, that skinny little bit on the A frame really does weigh around 400 kilos.
          http://i155.photobucket.com/albums/s296/storeben/SU/20170414_184952_edit_1492349513420.jpg
          And here we are all back together with no blemishes. Now it's just another forklift, truck drive and crane swing back into place.
          http://i155.photobucket.com/albums/s296/storeben/SU/20170415_143637_edit_1492349565529.jpg
          • tuna1957T Offline
            tuna1957
            ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ not enough "thumbs" for this... simply amazing ๐Ÿ‘
            • cottyC Offline
              cotty
              @tuna1957 said:
              :thumb: ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ not enough "thumbs" for this... simply amazing ๐Ÿ‘
              +1 ๐Ÿ‘
              my SketchUp gallery
              • BoxB Offline
                Speaking of thumbs, I've got 2.
                • Rich O BrienR Online
                  We've something in common!
                  • BoxB Offline
                    Two Thumbs!! my cats are working on that.
                    With the advances in technology today i'm seeing neural linked robotic prosthetic opposable thumbs, once they have that the furry little bastards will control the world.
                    • Bryan KB Offline
                      Great pics!
                      • BoxB Offline
                        As an update, there have been some issues with the 'client', pubic art is always problematic and keeping everyone happy is basically impossible.
                        However, two weeks after we reinstalled the second sculpture they have deigned to go and look at them. As a result of their 'viewing' I received an SMS telling me that they have been approved. I really wonder what these people think.
                        Sorry, no photos as such because they are still covered until they decide to unveil them, at a date to be decided.
                        • bazB Offline
                          baz
                          To quote John Cleese:
                          'Yes, well of course that's just the sort of blinkered, philistine, pig-ignorance I've come to expect from you non-creative garbage. You sit there on your loathsome spotty behinds squeezing blackheads, not caring a tinker's cuss about the struggling artist! You excrement! '
                          It was probly just an OH&S sign off tho.
                          Heading Ballarat way in a couple of weeks, so tis hopefully unveiled, otherwise might have to do a bit of undercover viewing.๐Ÿ˜„
                          • BoxB Offline
                            I'll give you the secret code Baz, to the gaffer tape holding down the fancy plastic tarp. And the magic spanner that will allow you to take the finger tight scaffold clamp off the corner so you don't have to jump the fence.
                            • bazB Offline
                              baz
                              Excellent, I will wear my hard hat and an old 'Access all areas' pass from a Moomba parade from 10 years ago.
                              BTW, did you know that Moomba means 'Up your bum' in Aboriginal. Not 'let's get together and have fun' as promoted by the organizers.
                              • BoxB Offline
                                It's been a long involved story but the sculptures have finally come out to see the light of day. They have moved to a beautiful home in a sculpture park not far from Ballarat. Here's a quick couple of snaps.
                                Hopefully I'll have better later. They are incredibly hard to photograph.
                                  A great setting, they look fantastic but I get your point about taking pictures. A better base would suit the sculptures better imho.
                                  • BoxB Offline
                                    There is a stainless steel pelmet that covers all the structural steel, it needed adjustment for the new location and will be fitted soon.
                                    • BoxB Offline
                                      Here's a slightly better shot showing some of the detail. The figure lights up differently depending on the angle of the sun. This was early morning so the sun is quite low from the right.
                                      And here is some direct, obvious and essential sketchup usage, the lifting rig I designed fully in sketchup. It allows us to clamp 3.5 tons of glass on two edges in a friction grip, lift it from horizontal, rotate it to vertical with one finger and set it down on it's base with nothing under it.
                                      • tuna1957T Offline
                                        tuna1957
                                        Great update Box. ๐Ÿ‘ Curious as to why they got relocated ๐Ÿ˜• . The lifting rig is a pretty sharp piece of design on your part also ๐Ÿ‘ .
                                        • boofredlayB Offline
                                          boofredlay
                                          Not enough words to express how cool this is.
                                          • BoxB Offline
                                            Thanks Boo.
                                            • BoxB Box referenced this topic on
                                            • 6
                                            • 6 / 6
