    Real world Wip. Glass sculptures.
    120 Posts 21 Posters 70.5k Views 21 Watching
    • BoxB Offline
      Here you go Baz, best I could manage in the wind today.
      It's still a construction zone as you can see.
        That is crazy!
        At night it will be amazing when lit up!
        • BoxB Offline
          Actually Rich it needs the sun to work, at night it will be more of a glowing obelisk with a deep pool of moving light at the base. The whole thing changes constantly with the movement of the sun. It will be different at different times of the day and the year and depending on the weather. Plus the whole block expands and contracts as it heats and cools, and we have used a semi fluid gel to create expansion joints and these layers "breath" so you get comet like bubbles shooting through the whole thing. It looks totally different all the way around.
          • bazB Offline
            baz
            That gave us a bit of a taste,ta.
            Looks amazing and proves that its a FPS experience ๐Ÿ˜„
            BTW: Was the guys fly open?
            • soloS Offline
              From the sides it looks like a Matrix image.
                Cool glass mille-feuille ! ๐Ÿ˜Ž
                • Bryan KB Offline
                  whoa! ๐Ÿ˜ฎ
                  • BoxB Offline
                    Here's a bit of an easter update.
                    There was a bit of an issue with the transportation that caused a problem in one of the expansion layers of the second sculpture that produced a clouding effect right in front of the girl's face. As a result we needed to split the block and remove a 400 kilo section. Once separated we could clean the faces and redo the expansion layer.
                    As this has all moved around 700km from the studio we had to find somewhere closer to work on it. Who would have thought you could split 400 kilos off a 3 ton block of glass in a tin shed in the back of beyond!
                    A few images....
                    Here she is with the light behind her before we start the repair. Only relevant because we never could see them like this in the studio.
                    http://i155.photobucket.com/albums/s296/storeben/SU/20170413_112933_edit_1492349420726.jpg
                    This is the block split into 2 sections, that skinny little bit on the A frame really does weigh around 400 kilos.
                    http://i155.photobucket.com/albums/s296/storeben/SU/20170414_184952_edit_1492349513420.jpg
                    And here we are all back together with no blemishes. Now it's just another forklift, truck drive and crane swing back into place.
                    http://i155.photobucket.com/albums/s296/storeben/SU/20170415_143637_edit_1492349565529.jpg
                    • tuna1957T Offline
                      tuna1957
                      ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ not enough "thumbs" for this... simply amazing ๐Ÿ‘
                      • cottyC Offline
                        cotty
                        @tuna1957 said:
                        :thumb: ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ not enough "thumbs" for this... simply amazing ๐Ÿ‘
                        +1 ๐Ÿ‘
                        my SketchUp gallery
                        • BoxB Offline
                          Speaking of thumbs, I've got 2.
                            We've something in common!
                            • BoxB Offline
                              Two Thumbs!! my cats are working on that.
                              With the advances in technology today i'm seeing neural linked robotic prosthetic opposable thumbs, once they have that the furry little bastards will control the world.
                              • Bryan KB Offline
                                Great pics!
                                • BoxB Offline
                                  As an update, there have been some issues with the 'client', pubic art is always problematic and keeping everyone happy is basically impossible.
                                  However, two weeks after we reinstalled the second sculpture they have deigned to go and look at them. As a result of their 'viewing' I received an SMS telling me that they have been approved. I really wonder what these people think.
                                  Sorry, no photos as such because they are still covered until they decide to unveil them, at a date to be decided.
                                  • bazB Offline
                                    baz
                                    To quote John Cleese:
                                    'Yes, well of course that's just the sort of blinkered, philistine, pig-ignorance I've come to expect from you non-creative garbage. You sit there on your loathsome spotty behinds squeezing blackheads, not caring a tinker's cuss about the struggling artist! You excrement! '
                                    It was probly just an OH&S sign off tho.
                                    Heading Ballarat way in a couple of weeks, so tis hopefully unveiled, otherwise might have to do a bit of undercover viewing.๐Ÿ˜„
                                    • BoxB Offline
                                      I'll give you the secret code Baz, to the gaffer tape holding down the fancy plastic tarp. And the magic spanner that will allow you to take the finger tight scaffold clamp off the corner so you don't have to jump the fence.
                                      • bazB Offline
                                        baz
                                        Excellent, I will wear my hard hat and an old 'Access all areas' pass from a Moomba parade from 10 years ago.
                                        BTW, did you know that Moomba means 'Up your bum' in Aboriginal. Not 'let's get together and have fun' as promoted by the organizers.
                                        • BoxB Offline
                                          It's been a long involved story but the sculptures have finally come out to see the light of day. They have moved to a beautiful home in a sculpture park not far from Ballarat. Here's a quick couple of snaps.
                                          Hopefully I'll have better later. They are incredibly hard to photograph.
                                            A great setting, they look fantastic but I get your point about taking pictures. A better base would suit the sculptures better imho.
                                            • 6 / 6
