    Toposhaper Crashing
    23 Posts 11 Posters 6.5k Views 11 Watching
      The output can only be as good as the input and with this dataset you are probably asking too much.
      If you set the Grid upper limit you will still not capture the complexity and hang SketchUp for huge amounts of time.
      Break it up into manageable sections, simplify the contours and work through it. Maybe work a a smaller selection of contours in a separate file to dial in your ideal output and go from there.
      But overall its a very complex dataset with many hard to find errors.
        cheekyky
        Hello, I'm having problems with the toposhaper extension tool.
        I'm running it on a very simple topography and it keeps crashing.
        I'm probably not using it well, I don't know... The tool 'from contours' seems to work perfectly but it's not as precise as toposhaper.
        If anyone could help me figure it out what's the problem it would be really useful.
        Thanks for the help,
        Ulysse
        HOUSE ASTHMA - TOPO - 2.skp
        Ruby Error - CLEANSING - 22-Nov-23 22_18_26.txt
        HOUSE ASTHMA - TOPO.skp
        Ruby Error - CLEANSING - 22-Nov-23 22_19_19.txt
        • fredo6F Offline
          fredo6
          It looks like you run TopoShaper from the inside of the Group or Component. Could you instead just seelct the Group / Component.
          • 2 / 2
