    Component attribute value is red with # at beginning
    3 Posts 2 Posters 3.9k Views 2 Watching
    • SJS66S
      SJS66
      Whenever I create a component (say a simple box) and try to 'fix' it's size in Component Attibutes by typing = in front of the LenX value for example, it turns red with a # in front of the value as in '#=100cm'. What is going on? What am I doing wrong? Can save a file with a component in it that I've tried to fix size and upload file if needed.
        Click to play...
        You need to set the LenX to handled by User input to see changes.
        • SJS66S
          SJS66
          I think I've got one for the next Doh Book. When constraining a component attribute it pays to delete the units from the value. I was leaving the cm in the value box and this is what was causing the #=100 cm in red. Noob I am.
