    Help. Lost my Mirror function when upgrading to 2016 Make
    5 Posts 4 Posters 796 Views 4 Watching
    • G
      Gene Davis
      I had an extension, a plug-in, called Mirror, don't know where I got it, but I used it all the time in my earlier versions, from way back.
      Cannot find anything like it in the extension warehouse.
      • massimoM
        massimo Moderator
        http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=mirror%26amp;submit=%3F
        • TIGT
          Many plugins/extensions are NOT available in The Extension-Warehouse.
          However, they are available from the SketchUcation PluginStore...
          [There a simple link in menu above...]
          For example, my Mirror is here:
          http://sketchucation.com/pluginstore?pln=Mirror
          If you want something and unusually it's not in the PluginStore, then look in EW, or for a few try Smustard.com.
          Another few are only available from their author's own web-site - however, at SketchUcation you should find posts containing useful links to most of these...
            There is also the Crai Ruby Depot! (for free Plugins)
            http://www.crai.archi.fr/rld/index.php English and French! πŸ˜‰
            Advantage : plugings are sorted by sections! 😎
            • TIGT
              Word of warning on the Crai Depot...
              It's a valuable repository of plugins, but many are out of date and newer/compatible versions are now available elsewhere...
              Especially if you have >=v2015...
              So check for the newest versions of the desired plugin, on any of the sites I have just listed.
              If there isn't one, then try using the Depot's version...
              However, if you get problems when SketchUp restarts, then you might need to remove the file[s] you've just installed... and seek compatible versions elsewhere...
