    Bending a honeycomb holed sheet
    6 Posts 5 Posters 658 Views 5 Watching
      alantch
      Hi Sketchup Gurus,
      I've got a flat sheet with honeycomb holes created. I would now like to bend the sheet on both sides to create a "U" shape but don't know what's the best way to do it. Is there an extension that can do this easily?
      https://s20.postimg.org/xcrs59nxp/honetcomb_sheet.jpg
      Thank you.
      Alan
        You could try CLF Shape Bender. Read the instructions carerfully. You'll need to make it a component with the proper orientation.
        Or you could try Radial Bend from FredoScale.
          http://sketchucation.com/pluginstore?pln=FredoScale
          • cottyC Offline
            cotty
            Another plugin would be http://sketchucation.com/pluginstore?pln=flowify
            my SketchUp gallery
            • BoxB Offline
              Another option, depending on the finished result you are after.
              Create the U shape with a suitable set of faces then use Components to faces to set the hexagons, I think this may be the only option that doesn't somehow distort your shapes.
              • cottyC Offline
                cotty
                Use a texture instead of the geometry and apply it to a U-shaped face.
                my SketchUp gallery
