    What Happened?
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    9 Posts 2 Posters 7.7k Views 2 Watching
    • ntxdaveN Offline
      ntxdave
      Here is an animation I created some time ago.
      Original
      I went in to it to look at some potential changes and when I played it now, it is reacting differently.
      Now
      I saved it to another file to try to make some adjustments but cannot seem to get it to work correctly any more. Any suggestions (short of starting over completely) would be appreciated.
      Press F1...thank me later
      • fredo6F Offline
        fredo6
        Dave,
        Previous version was full of bugs for the movements. So it might be that the new version, fixing the bugs, had changed the potential workarounds you were using.
        The best is to post the model, so that I have a look.
        Fredo
        • ntxdaveN Offline
          ntxdave
          Here is the model......
          Pendulum v4.skp
          • fredo6F Offline
            fredo6
            Thanks.
            I identified the problem and it should be fixed in the next version
            Fredo
            • ntxdaveN Offline
              ntxdave
              @fredo6 said:
              Thanks.
              Fredo
              Thanks Fredo - wish I would have tried/caught this sooner. Looking forward to the next release.
              On another topic, glad to hear Twilight will work with next release also.
              • fredo6F Offline
                fredo6
                Dave,
                By the way, the animation has been created with an old version of Animator, and the main animation is actually shown as a "Clip", not a "Film".
                What I will advise is to restablish it as a Film at the top is:
                • Create a New Fil
                • Insert the clip "Car Movement"
                • Explode the clip. So you should retrieve all your animation
                • Then you can purge the old clips if you wish.
                Note: if you don't do it, the animation will work anyway, but if you do, you will have a cleaner file for the new versions of Animator.
                Fredo
                • ntxdaveN Offline
                  ntxdave
                  Thanks Fredo"........
                  Does this mean I can do this with the current version or do I need to wait got the next release?
                  I had tried to update it but did not get it to work correctly.
                  • fredo6F Offline
                    fredo6
                    New version 1.0x is coming....
                    • ntxdaveN Offline
                      ntxdave
                      Thanks - will be good practice. Also looking at upgrading my Twilight license so I can look at that as well.
                      Keep up the GREAT work Fredo. Do I need to be looking at a budget for the public version as well?
