    Dimension Lines ... disappear
    4 Posts 3 Posters 3.2k Views 3 Watching
      djh
      Dimension Lines appear at certain angles and then disappear when I orbit around the model. All of the objects are on one layer.
      • pbacotP Offline
        Yes. That's how they are. They are like objects in the drawing. You want to make the view you need then do your dimensions. (save a scene)
        Place the dimensions on their own layer, so you can hide them. If you need different dimensions at a different view, you may need more than one layer to hide the dimensions which you wish not to see in respective views.
          There is an Expert dimension setting that will turn them off if they are foreshortened. You can adjust the slider to determine how foreshortened the need to be before they get hidden. Perhaps you have this enabled?
            djh
            Thank you, Dave R. That was the solution: to disable "Hide when foreshortened".
