🤑 30% Off | Artisan 2 on sale until April 30th
Buy Now
Dimension Lines ... disappear
Dimension Lines appear at certain angles and then disappear when I orbit around the model. All of the objects are on one layer.
Yes. That's how they are. They are like objects in the drawing. You want to make the view you need then do your dimensions. (save a scene)
Place the dimensions on their own layer, so you can hide them. If you need different dimensions at a different view, you may need more than one layer to hide the dimensions which you wish not to see in respective views.
Thank you, Dave R. That was the solution: to disable "Hide when foreshortened".
