    What am I missing
    4 Posts 3 Posters 538 Views 3 Watching
      Laggingbehind
      I've drawn / modified a model of a castor but when I bring it into the drawing the extents of the model is greater than anything you can actually see. I've tried exploding & purging but I still have the problem.. Not sure how to put a link onto this thread so if you search "Dodgy Castor" from the Warehouse it should be the only file there... Help would be much appreciated
        There's a very tiny hidden line segment way up in the corner of the bounding box. turn on Hidden Geometry and then open the component for editing. Drag a selection box around that upper corner of the component's bounding box and hit delete. The bounding box should fit the caster better.
        • BoxB Offline
          Open the model and hit ctrl+a, this will select everything in the model, now hold down shift and draw a selection box around the castor, this will deselect the castor, then hit delete on your keyboard, this will remove any stray edges floating in space,now hit shift+z and the castor should fill your screen.
          Dave was faster and he downloaded within SU so your geometry was wrapped for him and raw for me.
            Laggingbehind
            You two are stars...very much appreciated
