    Challenge
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    13 Posts 3 Posters 7.3k Views 3 Watching
    • chriC Offline
      chri
      I know how to do like "ANIMATION CUBE 1"
      I don't know how to do "ANIMATION CUBE 2"
      ( a rotation about the green corner, then a rotation about the angle blue)
      ( the example was made with another plugin )
      can you try ?
      je sais faire une animation telle que : "ANIMATION CUBE 1"
      je ne sais pas faire une animation telle que : "ANIMATION CUBE 2"
      ( une rotation autour de l'angle vert puis une rotation autour de l'angle bleu )
      ( l'exemple a ete fait avec un autre plugin )
      y arrivez-vous ?
      Chri
      cube colore.rar
      • chriC Offline
        chri
        @pilou said:
        THX to give the cube file!
        Merci de nous donner le Cube! 💚
        Il est dans le zip
        Skp file is in the zip
        Chri
          • fredo6F Offline
            fredo6
            Indeed this is a bug!
            Effectivement, c'est une grosse nouille!
              Ah yes! 😄 Skp file is in the zip no in the Rar! 💚
              Zip is more universal! ☀
              Sinon il me semble que c'est le bug que j'avais signalé! 😉
              Else seems that is the bug that I had signifyed!
              • fredo6F Offline
                fredo6
                I think I fixed it. So should go into the next release
                The best way is to use SPIN, not Rotation. To make a Spin which is not about the center of the object, just disable the small button showing a kind of center, next to the axis letter.
                Fredo
                  Seems excellent and indispensable! 😎
                  Does this GIF animation is "recorded" with Animator itself or with something like GifCam (free) ?
                  • fredo6F Offline
                    fredo6
                    I use Camtasia for video capture.
                    Here is the animation video generated by Animator
                      Cool of course! ☀
                      Can we imagine have a "Sound line" inside Animator for synchronize image + sound ?
                      • chriC Offline
                        chri
                        Fredo
                        Thanks Fredo6
                        Impatient to used it
                        Chri
                        • chriC Offline
                          chri
                          To achieve an animation type below, I think , i should use the "scale movement" to gradually decline the part.
                          Is it the right option?
                          I am unable to use the SCALE tool (pivot selection and scale factor).
                          Does "SCALE" is being developed or did I miss something?
                          Bonjour
                          Pour réaliser une animation du type ci-dessous , je pense qu'il faudrait utiliser la fonction "scale" pour la chute de métal que l'on ferai diminuer progressivement.
                          Est-ce la bonne option ?
                          Je n'arrive pas a utiliser l'outil SCALE ( sélection pivot et scale factor).
                          Est-ce que "SCALE" est en cours de développement ou est-ce que je loupe quelque chose ?
                          Chri
                            Et ici, tu as poussé (Déplacé) la petite boîte ?
                            • chriC Offline
                              chri
                              and you push the small box
                              Oui , mais c'est un trucage grossier.
                              Yes, but it is a rude trick.
                              Chri
