    From surface or plane to a stair?
    7 Posts 6 Posters 926 Views 6 Watching
    • H Offline
      herrschnitzel
      Hi is there a plugin which creates stairs out of surfaces or planes by a given angle?stair.JPG
      I think it wouldn't be possible for this example but for a component or group maybe?
      But again if I define direction and lowest and highest point it could be possible for a solid model...
      • utilerU Offline
        utiler
        Not that I know of mate. I'd just create two solids and subtract one from the other....
        Just Curious...
          Seems FredoScale can make that in a wink?
          • H Offline
            herrschnitzel
            wouldn't it be nice to have a plugin for it πŸ˜„
              You should write one.
              Although you would need to manually create the stair step profile, you could use TIG's Extrude Edges by Rails to get the faces.
              Making the stair step profile is trivial.
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                I think the simplest way is, as Utiler wrote it, to use two separate shapes and do an intersection and then some clean-up.
                Click in sequence on the Scenes tabs of this SU file for ideas.
                Stairs from an inclined plane.skp
                • JQLJ Offline
                  JQL
                  This is right!
                  If you don't have a Pro version you can do the same with "intersect faces with..." from the right click context menu.
                  I prefer using it most of the time as most of the time I have no solids.
                  www.casca.pt
                  Visit us on facebook!
