๐Ÿ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
From surface or plane to a stair?
7 Posts 6 Posters 538 Views 6 Watching
  • H Offline
    herrschnitzel
    Hi is there a plugin which creates stairs out of surfaces or planes by a given angle?stair.JPG
    I think it wouldn't be possible for this example but for a component or group maybe?
    But again if I define direction and lowest and highest point it could be possible for a solid model...
    • U Offline
      utiler
      Not that I know of mate. I'd just create two solids and subtract one from the other....
      purpose/expression/purpose/....
        Seems FredoScale can make that in a wink?
        • H Offline
          herrschnitzel
          wouldn't it be nice to have a plugin for it ๐Ÿ˜„
            You should write one.
            Although you would need to manually create the stair step profile, you could use TIG's Extrude Edges by Rails to get the faces.
            Making the stair step profile is trivial.
              Jean Lemire
              Hi folks.
              I think the simplest way is, as Utiler wrote it, to use two separate shapes and do an intersection and then some clean-up.
              Click in sequence on the Scenes tabs of this SU file for ideas.
              Stairs from an inclined plane.skp
                JQL
                This is right!
                If you don't have a Pro version you can do the same with "intersect faces with..." from the right click context menu.
                I prefer using it most of the time as most of the time I have no solids.
                www.casca.pt
                Visit us on facebook!
