    Avoid a nightmare?
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    6 Posts 2 Posters 5.7k Views 2 Watching
      Seems axes of box's object Animator are not the same than the object?
      So for this simple sphere after a rotation
      this translation gives a funy result not wanted!
      Original component has normal axes of Origine on the center of the ball!
      boule01.zip
      • fredo6F Offline
        fredo6
        Pilou,
        Thanks for signaling. I will have a close look.
        Fredo
        • fredo6F Offline
          fredo6
          Pilou,
          That's a tricky one, because I need to think what to do with the local axes, when the seuqnece is created in context (here, after the rotation).
          Currently, translation are stored in local coordinates outside of context, so that Z Local becomes a vertical because the original sphere is initially oriented with Z upward.
          So, interesting problem, which I will try to resolve.
          Fredo
            Bon courage! β˜€
            • fredo6F Offline
              fredo6
              Should be possible with version 1.0v
              Fredo
                Yep! πŸ˜„
                PS Where can I have N° version of Animator inside SU Screen ? 😳
