    Select line segments upto first junction and weld
    4 Posts 3 Posters 615 Views 3 Watching
    • M
      MLUY
      Is there a plugin which can weld line segments upto the first encountered junction?
      So where its first connected to another line?
      Normally when you double click on a line segment it only selects all other connected lines
      Thanks!
      • TIGT
        If you want to miss off just one line then double-click to select all and immediately Ctrl+Shift click on the unwanted line to deselect it - the rest will stay selected.
        You can also Ctrl+Shift and use a fence to remove multiple things from the selection.
        Or use a fence to select just what you want -
        drag the fence's corners either:
        right>left to include everything that is within the fence, even those things which are only partially within it
        or
        left>right to include only objects which are wholly within the fence, and anything straddling the fence are not included.
        • BoxB
          Have a look at Fredo's Curvizard.
          • M
            MLUY
            Thanks that worked
