    REQ: Federal Standard Colors 595 all versions
    4 Posts 3 Posters 8.0k Views 3 Watching
    • deaneauD
      deaneau
      Hi at@all
      i search the FED STD 595 as RGB Table (not hex value).
      Dean
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
        How about this: http://www.spmodelismo.com.br/material/tintas/fs595b.pdf
        • TIGT
          Here's an extract from that PDF in CSV format - opens in Excel, or read into a Ruby in an empty SKP to make materials...
          There are 5 columns - read the PDF for help...
          Col.A is 'Luster' - e.g. 1
          Col.B is the FS595b 'color reference' - e.g. 32
          Col.C,D,E are the R,G,B values - e.g. 55,39,38
          To make the materials use
          lines=IO.readlines(csvpath)
          The full path to the CSV file... then, skipping line 0 with the headers...
          mats=Sketchup.active_model.materials
          lines[1..-1].each{|line|
            line.chomp! ### strip \n
            l,n,r,g,b = line.split(',')
            ### we include 'l'
            m=mats.add('FS595b_'+l+'_'+n)
            m.color=Sketchup;;Color.new(r.to_i,g.to_i,b.to_i)
          The 547 new materials are named "FS595b_1_32" etc...
          Save them all as a Collection of SKM files to use in any SKP...
          I have also attached a ZIP containing the 547 SKM files - but you might like to change the naming convention, and rerun the above steps etc...
          fs595b.csv
          FS595b.zip
          • deaneauD
            deaneau
            Hi TIG thank you, however this is an older version. the actually version is 595C
            http://www.gsa.gov/portal/content/142623
            P.S. i have seen your answer to day
