    REQ: Federal Standard Colors 595 all versions
    4 Posts 3 Posters 7.8k Views 3 Watching
    • deaneauD Offline
      deaneau
      Hi at@all
      i search the FED STD 595 as RGB Table (not hex value).
      Dean
        How about this: http://www.spmodelismo.com.br/material/tintas/fs595b.pdf
          Here's an extract from that PDF in CSV format - opens in Excel, or read into a Ruby in an empty SKP to make materials...
          There are 5 columns - read the PDF for help...
          Col.A is 'Luster' - e.g. 1
          Col.B is the FS595b 'color reference' - e.g. 32
          Col.C,D,E are the R,G,B values - e.g. 55,39,38
          To make the materials use
          lines=IO.readlines(csvpath)
          The full path to the CSV file... then, skipping line 0 with the headers...
          mats=Sketchup.active_model.materials
          lines[1..-1].each{|line|
            line.chomp! ### strip \n
            l,n,r,g,b = line.split(',')
            ### we include 'l'
            m=mats.add('FS595b_'+l+'_'+n)
            m.color=Sketchup;;Color.new(r.to_i,g.to_i,b.to_i)
          The 547 new materials are named "FS595b_1_32" etc...
          Save them all as a Collection of SKM files to use in any SKP...
          I have also attached a ZIP containing the 547 SKM files - but you might like to change the naming convention, and rerun the above steps etc...
          fs595b.csv
          FS595b.zip
          • deaneauD Offline
            deaneau
            Hi TIG thank you, however this is an older version. the actually version is 595C
            Page not found
            (www.gsa.gov)
            P.S. i have seen your answer to day
