    Append character to component/s selection
    13 Posts 4 Posters 1.3k Views 4 Watching
      I need to append a character to a selection of components each with a different name.
      eg - name-01 to become name-01w
      this would need to happen to all the components I've selected. Anyone know of a tool that does this?
      • JQLJ
        JQL
        Rename by Layer by Renderiza.
        You can rename by layer as the name of the plugin, but you can also rename components and groups by selection.
        You can append a suffix and a prefix and you can affect definition name or component name or even both.
        It fulfills all your component's naming requirements!
        EDIT: It looks good too! Here it is:
        http://sketchucation.com/pluginstore?pln=RND_Renamer_v1.0.0
        www.casca.pt
        Visit us on facebook!
          but from what i can tell it doesn't allow me to suffix 'W' onto Name-01
          • JQLJ
            JQL
            You're right...Sorry...
            What I use to do is add a number suffix or allow it to assign the definition numbers automatically.
            www.casca.pt
            • JQLJ
              JQL
              Suggestion:
              Shouldn't your convention be letters on the prefix and #N numbers on the suffix?
              This way, you're sticking to Sketchup convention and making an unique component will work...
              www.casca.pt
                It's for a grass pack I have and it has grass species with the blades cut, uncut and withered
                So to signify the difference in appearance the component will be suffixed with w for withered and c for cut.
                [edg3d:ihg61x36]QxaupfdO8Mt4ZJE[/edg3d:ihg61x36]
                • JQLJ
                  JQL
                  They're looking really nice and judging from your vegetation output they should render fast.
                  My real question is... what is the Font type you used on the ad? I really like it!
                  www.casca.pt
                    I think it's Raleway. Need to check though.
                    • sdmitchS
                      sdmitch
                      Are we talking Instance name or Definition name? If you change the definition name before making the instance unique, you change it for all instances if they are selected or not.
                      http://sdmitch.blogspot.com/
                      • TIGT
                        A simple one liner copy/pasted+<enter> in the Ruby Console would do this in a trice.
                        I assume you are wanting to rename the component-definitions rather than the instances [these can have separate names], and that you want to rename all definitions in the model [it could also be done on just those selected too see below].
                        Edit the x="" part to the character[s] you want to add onto the name e.g. W or -W or -something_witty...
                        For all definitions in the model
                        x="W";Sketchup.active_model.definitions.each{|d|next if d.image?||d.group?;d.name=d.name+x}
                        For selected definitions only...
                        x="W";s=[];Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|i|s<<i.definition};s.uniq.each{|d|d.name=d.name+x}
                        You can rename instances in a similar way...
                          Are we talking Instance name or Definition name? If you change the definition name before making the instance unique, you change it for all instances if they are selected or not.[/quote]
                          Hi Sam,
                          I need a global name change so all instances inherit the suffix.
                          • sdmitchS
                            sdmitch
                            Hi Sam,
                            That being the case, perhaps this will work for you
                            mod = Sketchup.active_model
                            sel = mod.selection
                            pos = "W"; whr = "Suffix"
                            val = UI.inputbox(["Add;","  As;"],[pos,whr],[nil,"Prefix|Suffix"],"Rename Definitions")
                            if val
                              pos,whr = val
                              cis =sel.grep(Sketchup;;ComponentInstance);cdn = [];
                              cis.each{|ci|
                                next if cdn.include?(ci.definition.name)
                                ci.definition.name = pos + ci.definition.name if whr=="Prefix"
                                ci.definition.name += pos if whr=="Suffix"
                                cdn << ci.definition.name
                            • TIGT
                              Each definition has a unique name.
                              Editable in the Component Browser etc...
                              A definition can have one or more instances placed in the model.
                              If you use 'make_unique' on one [or more] of several instances, then the instance[s] gets a new definition, duplicated from the original, with its name getting an incrementing suffix auto-appended - e.g. 'widget' becomes 'widget#1'...
                              Any instance can also have its own individual name [set in Entity Info] - these instance-names are not directly connected to their definition's name.
                              Unlike definitions instance-names can be repeated and shared by several instances, and even instances of different definitions !
