    Find out if point is inside solid
    scheduled pinned locked moved Developers' Forum
    13 Posts 8 Posters 2.2k Views 8 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
    • I Offline
      icatic
      Hello,
      Is there a way using the ruby API to find out if a point is inside the actual volume of a solid instance/group?
      Thanks,
      Valdemar
      one-reply-to-this-post last-reply-time reply quote 0
        Ruts
        I'm not sure if there's an existing extension for this, but I use this kind of in my extension. Neither am I sure if my method is easiest way to go, it's quiet computing-intensive if you're solid is made out of many faces.
        NOTE: a line is infinite long in both directions and a half line is infinite long in one direction.
        It is based on the principle that a half line that starts in your point should intersect your solid an odd number of times. So you have to check every face of the solid if it intersects with the half line.
        Method intersect_line_plane calculates the intersection of the line (in both directions) and the plane of the face. You have to check if the intersection is on the half line and on the face of the plane.
        For checking if the intersection is part the face again it can be done with another half line which starts in the intersection and is parallel to the plane of the face. Once again the intersection is part of the face if the half line intersects the edges of the face an odd number of times. So you should check every edge of the face and see if the half line intersects it. The method intersect_line_line calculates the intersection between the line of the half line and the line of the edge. Check if this intersection is part of the half line and the edge.
        Hopefully this is helpfull to you, it may be fomulated a little chaotic. I can share some of my code if you want.
        • sdmitchS Offline
          sdmitch
          @icatic said:
          Hello,
          Thanks,
          Valdemar
          In the simplest case, you can test that the bounds of instance/group contains the point.
          inside=iorg.bounds.contains?(point)
          http://sdmitch.blogspot.com/
            First check if the point is within the solid.bounds...
            If not, then it is not inside, although if it's inside then of course it might be on its 'surface' and not actually inside it !
            If it is a true manifold solid then all of its face.normal's should point 'outwards'.
            Use this test on the ' point':
            Choose an arbitrary ' vector' like [1,0,0]
            hit = model.raytest(point, vector)
            If it returns no hit at all then it definitely is outside of everything - at least using that 'vector'!
            If it returns a hit, then using that ' hit' array you can test if
            hit.include?(solid)
            If no hit then perhaps 'reverse' the vector and retest...
            Assuming we get a hit that includes the 'solid'...
            Check if the hit includes a 'face'.
            If it's an edge, perhaps adjust the vector slightly to see if you can actually hit a face !
            Assume you have hit a face, now compare the vector and the face.normal using
            angle = vector.angle_between(face.normal)
            If angle < 90.degrees then it is 'inside'.
            If its >= then its outside.
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              Maybe this could help: http://clb.demon.fi/MathGeoLib/nightly/docs/Polyhedron.cpp_code.html#532
              General strategy: pick a ray from the query point to a random direction, and count the number of times the ray intersects a face. If it intersects an odd number of times, the given point must have been inside the polyhedron.
              • G Offline
                Garry K
                Randolf Franklin solved this problem back in the 1970's
                Here is his original 2D code for a single polygon
                int pnpoly(int nvert, float *vertx, float *verty, float testx, float testy)
                  int i, j, c = 0;
                  for (i = 0, j = nvert-1; i < nvert; j = i++) {
                    if ( ((verty[i]>testy) != (verty[j]>testy)) &&
                	 (testx < (vertx[j]-vertx[i]) * (testy-verty[i]) / (verty[j]-verty[i]) + vertx[i]) )
                       c = !c;
                  return c;
                I ran a modified version of this code on very old mobile computers 80186 processor running at 18 megahertz. We used it to determine which State or Province your vehicle is in.
                3D isn't much more difficult but you do have to look at each face and see if your ray passes through it or not.
                • sdmitchS Offline
                  sdmitch
                  @icatic said:
                  Hello,
                  Thanks,
                  Valdemar
                  Here is my solution. If it can't find an opening is 1000 tries, the point is most likely inside the solid.
                  def is_point_inside(pt,cg)
                  	return false unless cg.manifold?
                  	return false unless cg.bounds.contains?(pt)
                  	1000.times{
                  		vec=Geom;;Vector3d.new(rand*(rand<=>0.5),rand*(rand<=>0.5),rand*(rand<=>0.5))
                  		h=Sketchup.active_model.raytest([pt,vec]);
                  		return false unless (h && h[1].include?(cg))
                  	return true
                  • fredo6F Offline
                    fredo6
                    Assuming you have a true solid,
                    • You have to test first if the point is on a face of the solid (you decide if it is 'in' or 'out')
                    • otherwise, you take one arbitrary oriented direction (say X direction) and check the number of times it crosses a face of the solid. It must be an odd number if inside, or even if outside. The trick is that you must keep track of the intersection points to make sure you do not reuse the same point twice or more times (for instance when the half-line crosses an edge or a vertex).
                    Fredo
                    • I Offline
                      icatic
                      Thanks for all the replies!
                      I ended up using the method that both Ruts and fredo6 explained. There's a special circumstance when the arbitrary line runs along a face parallell to the line that I had to consider in the code (the skip_intersection part). Here's the code I ended up with:
                      def solid_contains_point?(solid, point, include_shell = true)
                        return false unless solid.manifold?
                        return false unless solid.bounds.contains? point
                        point = point.transform(solid.transformation.inverse)
                        line_vector = Geom;;Vector3d.new(1, 0, 0)
                        line = [point, line_vector]
                        previous_intersection_point = previous_classify_result = nil
                        intersection_points = Array.new
                        solid.definition.entities.find_all { |e| e.instance_of? Sketchup;;Face }.each { |face|
                          intersection_point = Geom.intersect_line_plane(line, face.plane)
                          if intersection_point and intersection_point != previous_intersection_point
                            classify_result = face.classify_point(intersection_point)
                            point_on_face = [Sketchup;;Face;;PointInside, Sketchup;;Face;;PointOnVertex, Sketchup;;Face;;PointOnEdge].include? classify_result
                            angle = line_vector.dot(point.vector_to(intersection_point))
                            if point_on_face and ((angle >= 0 and include_shell) or (angle > 0 and not include_shell))
                              intersection_points.push [intersection_point, classify_result]
                              previous_intersection_point = intersection_point
                        previous_skip_intersection = false
                        intersections = 0
                        intersection_points.sort! { |a,b| point.vector_to(a[0]).length <=> point.vector_to(b[0]).length }.each { |array|
                          intersection_point = array[0]
                          classify_result = array[1]
                          # skip intersection point if there's another face that contains both the current
                          # intersection point and the previous intersection point
                          if previous_classify_result and previous_classify_result != Sketchup;;Face;;PointInside
                              solid.definition.entities.find_all { |e| e.instance_of? Sketchup;;Face }.each { |e|
                                if classify_result == Sketchup;;Face;;PointOnVertex
                                  if e.vertices.find_all { |vertex| vertex.position == intersection_point or vertex.position == previous_intersection_point }.size == 2
                                    skip_intersection = true
                                    break
                                elsif classify_result == Sketchup;;Face;;PointOnEdge
                                  if e.edges.find_all { |edge| intersection_point.on_line?(edge.line) or previous_intersection_point.on_line?(edge.line) }.size == 2
                                    break
                          # count all intersection points connected by face parallell to and on line as one intersection
                          intersections += 1 if previous_skip_intersection and !skip_intersection
                          previous_skip_intersection = skip_intersection
                          next if skip_intersection
                          intersections += 1
                          previous_classify_result = classify_result
                        intersections.odd?
                      • fredo6F Offline
                        fredo6
                        That should make it.
                        Just 2 remarks
                        • I would cache the list of valid classify_status outside the loop
                        • I would construct the list of intersection points without bothering whether this is a vertex or on edge and then sort the list by the distance to the point or X, Y, Z coordinates and eliminate the redundant points (which are necessarily in sequence)
                        Fredo
                        • P Offline
                          Paciente8159
                          Is this OK?
                          The same principle. A raycast from the testing point. I'm only counting how many faces it sees in one direction and only if the point hits the face on the inside (from the testing point)
                          To also include the outter shell of the solid the point classification must be changed to validade Vertex and Edges hits.
                          Here is the code
                          def point_insidesolid?(point, solid)
                          		#vector that goes through the origin
                          		vec = Geom;;Vector3d.new(1,0,0).normalize
                          		counter = 0
                          		solid.entities.grep(Sketchup;;Face).each do |face|
                          			pt = Geom.intersect_line_plane([point,vec], [face.vertices[0].position, face.normal])
                          			if(!pt.nil?)
                          				if(face.classify_point(pt)==Sketchup;;Face;;PointInside)
                          					if(pt.x>point.x)
                          						counter +=1
                          		return false unless counter%2!=0
                          		return true
                          • sdmitchS Offline
                            sdmitch
                            @paciente8159 said:
                            Is this OK?
                            Here is the code
                            > 		counter = 0
                            > 			if(!pt.nil?)
                            > 					if(pt.x>point.x)
                            > 						counter +=1
                            > 					end
                            > 				end
                            > 			end
                            > 		end
                            > 		return true
                            > 	end
                            It should if "point" is truly inside the solid. If it is a model point then it will need to be transformed by the inverse of the solid's transformation.
                            • P Offline
                              Paciente8159
                              Yes the point must be in the solid(group) coordinate space.
                              I've changed the code a bit to allow shell (outer face) testing
                              Here it is:
                              Edited:
                              After some testing still something was not OK.
                              I realized that when the ray crosses an edge it hits 2 different planes and through a vertice it can hit an unknown number of faces. The solution I came is that the ray crosses the solid in only one point. So instead of keeping track of how many faces it hits, I register all points the ray hits the solid and then perform a uniq-like operation to the array to count the number of points/hits.
                              I've updated the code.
                              For the filtering uniq! doesn't work (guessing because it uses eql? and this is not implemented in Point3d)
                              Also tried
                              pts.uniq! {|pt| pt.to_a}
                              but it didn't worked, but since the raycast is parallel to X axis comparing x coordinate does the trick
                              def point_insidesolid?(point, solid, exclude_surface=false)
                              		vect = Geom;;Vector3d.new(1,0,0)
                              		pts = []
                              			if(FaceTools.is_pointof_face?(point,face))
                              				return true unless exclude_surface
                              				return false
                              			else
                              				pt = Geom.intersect_line_plane([point,vect], [face.vertices[0].position, face.normal])
                              				if(!pt.nil?)
                              					if(FaceTools.is_pointof_face?(pt,face) && pt.x>point.x)
                              						pts.push pt
                              		ptsuniq = pts.uniq {|pt| pt.x}
                              		return ptsuniq.count%2!=0
                              	def point_insideface?(point,face)
                              		case(face.classify_point(point))
                              			when Sketchup;;Face;;PointInside, Sketchup;;Face;;PointOnVertex, Sketchup;;Face;;PointOnEdge
                              				return true
                              		return false
                              • first-post
                                last-post
