    Push pull straight
    8 Posts 5 Posters 845 Views 5 Watching
      MLUY
      I have drawn a circle on a curved surface with [tools on surface]. This needs to be pulled up as a cylinder. I have done this with [joint push pull] but the top is an now under an angle and I need it to be horizontal.
      Is there an easy way to do this?
      • jujuJ Offline
        juju
        OLD SCHOOL METHOD:
        construct a box (or flat surface) larger than the cylinder protrusion, move it to the required level, select all, interact, and remove the surplus undesired content
          Pull it up a bit farther than you need and use a cutting plane to cut it off flat.
          I probably would have drawn the flat shape at the top and used Push/Pull to push it down through the foil shape and trimmed off the bottom.
            MLUY
            Thanks guys, I knew it was simple just got stuck on it
            Lightning fast response
            I just love this site
            • JQLJ Offline
              JQL
              if you use joint push pull you should investigate it a bit better. It is able to push pull leaving the top of the cilinder flat.
              Use vector push pull and search for a red line... πŸ˜„
              Click the gif:
              www.casca.pt
              Visit us on facebook!
              • JQLJ Offline
                JQL
                Oops pilou was faster
                www.casca.pt
                  The more easy is one time again a little plugin of Fredo! πŸ˜„
                  As you just used it, it's always open! πŸ’š
                  Life is too short! πŸ˜‰
                    No problemo! β˜€
