πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Push pull straight
8 Posts 5 Posters 687 Views 5 Watching
    MLUY
    I have drawn a circle on a curved surface with [tools on surface]. This needs to be pulled up as a cylinder. I have done this with [joint push pull] but the top is an now under an angle and I need it to be horizontal.
    Is there an easy way to do this?
      juju
      OLD SCHOOL METHOD:
      construct a box (or flat surface) larger than the cylinder protrusion, move it to the required level, select all, interact, and remove the surplus undesired content
        Pull it up a bit farther than you need and use a cutting plane to cut it off flat.
        I probably would have drawn the flat shape at the top and used Push/Pull to push it down through the foil shape and trimmed off the bottom.
          MLUY
          Thanks guys, I knew it was simple just got stuck on it
          Lightning fast response
          I just love this site
            JQL
            if you use joint push pull you should investigate it a bit better. It is able to push pull leaving the top of the cilinder flat.
            Use vector push pull and search for a red line... πŸ˜„
            Click the gif:
            www.casca.pt
            Visit us on facebook!
              JQL
              Oops pilou was faster
              www.casca.pt
                The more easy is one time again a little plugin of Fredo! πŸ˜„
                As you just used it, it's always open! πŸ’š
                Life is too short! πŸ˜‰
                  No problemo! β˜€
