    Triple click
    7 Posts 5 Posters 735 Views 5 Watching
    • S
      samyell77
      I have a bit of an odd issue where, working with geometry, if I single click I can select an individual line or face, if I double click I can select a face and its lines but if I triple click it no longer selects all the geometry. I've tried multiple click combinations and even adjusted the mouse click speed but no joy.
      I used the be able to triple click and be able to select all the geometry but now can't do so - it makes selecting very trick.
      Anyone else had the same problem or any ideas on a solution. I have auto detect set in the click style prefs.
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • S
        samyell77
        This has been an issue since upgrading to 2016....
        SU Pro 2016
        PC Windows 10
        16gb RAM
          Is it possible it is a problem with your mouse? I've been using SU2016 pretty heavily and haven't seen this problem. i use that triple click thing all the time and I'm sure I'd have noticed if it wasn't working like it used to.
          • S ShepherdS
            S Shepherd
            If you are using a wireless mouse, does it have a usb receiver?
            If so, have you added a usb thumbdrive or other device.
            I noticed some mouse & keyboard issues recently while a usb 3 stick was plugged in.
            Only a thought.
            Shep
            • HornOxxH
              HornOxx
              @s shepherd said:
              ...I noticed some mouse & keyboard issues recently while a usb 3 stick was plugged in...
              of course I don´t know if that´s the reason, but since I use exactly the same notebook as Samyell, I experienced today for the first time what you're describing here. I pluged in a usb3 stick (at the right side of the Dell Precision M4800, where it´s usb2 ports are located) and my usb wireless mouse finished working completely, even the touchpad of the notebook...
              When I pluged in the usb3 stick at the left side of the notebook, where it has it´s usb3 ports actually, everything was fine again...
              I would also suggest any mouse issue
              never trust a skinny cook
              • V
                ValmontR
                I will add that at a certain number of edges/faces (about 8.2 million edges) triple click begins to fail and soon is no longer possible. A hard limit has existed in SU for a LONG time, although it has increased with versions. I think it might be 10 years ago the limit was 200k.
                Cheers,
                r
                • S
                  samyell77
                  Ran a disc cleanup, trashed a load of files and restarted and everything seems to be back to normal now. Thanks for all the suggestions tho peeps.
                  Sam
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
