    2015 to 2016. Do I have to redo everything again?
    7 Posts 4 Posters 1.1k Views 4 Watching
      CalypsoArt
      I have 2015 with my plugins, my Tool bars, my shortcuts, everything set up, not only the way I like it, but with customizations that I've made consistent across my 3 main software packages. Will moving to 2016 mean I will have to redo all this again. Are there any options to cut down on the work?
      • cottyC Offline
        cotty
        • You can export and import shortcut settings.
        • If you used the plugin store for the plugin installation, you can use the one click bundle function.
        • You can make a screenshot of your toolbar arrangement and use it as a template for the new version (you can't transfer the positions automatically)
        • Materials, Styles, ... can be copied over in the filesystem.
        my SketchUp gallery
          sepo
          OK, I have Su2016 pro and wanted to move some plufgins from 2015. In 2015 all plugins are stored in plugins folder. However plugins in 2016 are nowhere to be seen although I installed via .rbz some of them. Any idea where are the plugins in 2016?
          Best wishes for New Year and thank you.
          • cottyC Offline
            cotty
            C:\Users[username]\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
            my SketchUp gallery
              sepo
              I know, but they are not there. πŸ˜• Maybe to add that it is on the w10.
              • massimoM Offline
                massimo Moderator
                This should return the path to the plugins folder:
                Sketchup;;find_support_file("Plugins")
                Copy it in the ruby console and press enter.
                  sepo
                  Hi Massimo
                  This returns same place. There is plugins folder but nothing but su standard extensions.
                  I think I will have to reinstall Su and see what happens. Thanks.
