    Rhino export to sketchup render problem (help)
    renderpluginsextensions
    2 Posts 1 Posters 1.3k Views 1 Watching
      monkers
      Hi Guys,
      Can someone please give me some advice here I'm stumped with an import/rendering problem I'm having.
      So.. I need a lot of features in SU and I have to use it for my rendering but.. I love the power of Rhino and grasshopper I have been using it on and off and I'm starting to think it could have a bigger place in my work flow.
      My problem is getting my Rhino model to export into SU properly. I have no idea what its doing here can someone please have a look. I exported form rhino strait to skp And have tried multiple ways of exploding the model before I export. Ideally I would like to preserve layers and textures for ease of organisation in the sketchup side. The actual geometry seems to import fine but once I apply a glass texture and render its gets weird..
      Cheers in advance.
      M
      weird render
      imported skp file
        monkers
        For some reason VR is scaling up each exported component of eash window pane. Is there an easy batch fix for this?
        If I explode the group of window components it seems to render okay. but I would rather not have to do this each time/variation. As I'm also worried about the file becoming unnecessarily large.
        extracted pane
        exploded render
