    Translucency rendered correctly with RT but not R
    renderpluginsextensions
    3 Posts 2 Posters 747 Views 2 Watching
    • K Offline
      kokoriko17
      So I've followed literally every tutorial on earth to create a lampshade with translucency and after wasting 5 hours I realized that Vray RT does render the desired output but surprisingly not the final renderer.
      I've used 2 sided material and set the color to RGB 104 with forced 1 side.
      I hit R and below is the output.
      https://i.gyazo.com/d0c8529b913af3dbeb1d76b79ef4a0fe.png
      I hit RT ( CUDA ) and below is surprisingly a different output
      https://i.gyazo.com/e1461d43796f65202e87176686a019d3.png
      Everything else is rendered correctly in VRAY R
      https://i.gyazo.com/030bb0eab725fc3b9aa326a7f53d9af1.jpg
      https://i.gyazo.com/1e8e4ef456bf056bd1eb84b3b798f5e8.jpg
      Machine :
      iMac 27 Core i7 3.9 GHz
      32GB RAM
      PCIe SSD
      Nvidia GTX 780
      Appreciate some guidance.
      Cheers.
      • K Offline
        kokoriko17
        37 views and no reply which is a bit sad but I managed to fix it. For some weird reason I had to reverse faces, paint and revert. Now it's rendering correctly.
        https://i.gyazo.com/72b643856265afdb08a29c16da2550bb.jpg
        A note to developers, sphere lights are way too bright for an intensity of 30 if they are within a group. I had to put them outside the chandelier group for a proper brightness.
        • TedVitale_CGT Offline
          TedVitale_CG
          Backside faces are not currently supported by GPU rendering in Sketchup, That may be the reason you were having some errors.
          Ted Vitale
          Owner | Creative Director
          http://www.voxl.vision
