    Vray 2.0 NOT Rendering!!
    renderpluginsextensions
    2 Posts 2 Posters 772 Views 2 Watching
    • G Offline
      GaboM5
      Hi everybody!
      I have this recurrent problem. Vray get stuck at a certain point when rendering.
      When I'm doing a test render everything its just fine. Very low res, low image, color mapping at Fixed or Subd. Light Cache at 500, Image size 600*400. Very low subd for materials, lights and shadows.
      The problem seem to appear whenever it wants. Everything seems normal but suddenly, when im trying to render, vray does not get pass 5% at light cache. And just to get to that 5% progress, it took my PC over 2 hours. The only thing that i've noticed its that my CPU gets crazy, starts working at 100% load, then drops down to 14%, gets back to 80-90% and drops back again, so on and so forth.
      This problem had happened already several times in the last few months, but just as it appears goes aways.
      I have no idea what could be happening, every help would be really appreciated.
      Thanks!!!!!
      MY PC specs:
      Windows 7
      i7
      GeForce GT730
      16 GB Ram
      1Tb hard drive
      250 SDD
      Vray Settings
      bucket at 32
      4000 Dyn Memory Lim
      Light Cache 500
      Color Mapping FIxed/Subdiv
      No Antialising
      DMC .85-0.01-8-1.0
      Irradiance Map -4,-3/50-20
      • P Offline
        peerman
        Do you have any materials with displacement? Try turning it off in the options menu and try again. Maybe that helps?
        Regards,
        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
