    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 508.2k Views 71 Watching
    • G Offline
      Garry K
      For some unknown reason Andrew hasn't picked up the PM that I sent him.
      Users can also contact me via my web site.
      http://cabmaker32.com/contact/
      I see these emails just as fast as if you emailed me directly. I also respond fairly quickly. After I respond you would have my email address and I will have yours.
      The last few releases are in response to a few users that have had some issues. They emailed me and I dug into the issues. Thanks to Scott, Bill, Grant and Piere.
      • utilerU Offline
        utiler
        Thanks Garry, all sorted now!
        Just Curious...
        • G Offline
          Garry K
          Here is a video with cab maker and cut list pro integration.
          • G Offline
            Garry K
            I'm thinking about adding a feature where you create a cabinet with create options:
            Create Options
            Drop down that has "Full Cabinet", "Door Fronts Only", "Door Fronts and Frames Only"
            • utilerU Offline
              utiler
              Hi Garry, is there a way for Cabmaker to identify material list as per what is in the current model?
              Just Curious...
              • G Offline
                Garry K
                Yes - Go to the defaults tab.
                That will show you what all the defaults are.
                I do save defaults settings with each model.
                • utilerU Offline
                  utiler
                  Thanks but my defaults only show imperial_rules & imperial_rules_upper...?
                  How do I change it to metric?
                  Just Curious...
                  • G Offline
                    Garry K
                    From the main menu choose
                    Extensions \ GKWare CabMaker \ Cab Maker - Edit Config
                    Set Filter to Imperial to filter out Imperial
                    OR - depending upon what you want
                    Set Filter to Metric to filter out Metric
                    • utilerU Offline
                      utiler
                      I have that set to metric but still the defaults show imperial....
                      Just Curious...
                      • G Offline
                        Garry K
                        Yes - you are filtering out Metric.
                        This setting will show everything else.
                        • G Offline
                          Garry K
                          Version 1.0.33 is now ready to download.
                          1. Added width adjustment for cabinet sides and top / bottoms.
                          2. Added bottom gap for frameless construction with overlay doors.
                          3. Modified reports. Changed Solid to Dimensioned Lumber so that the report would work with Cut List Plus.
                          • utilerU Offline
                            utiler
                            Gotcha. Filtering is filtering out. A bit back to front but I understand now. thanks.
                            Just Curious...
                            • soloS Offline
                              solo
                              Cabinet maker not working if you have Plusspec installed, I tried using it but it does not create any geometry or open any dialogs, I am assuming Plusspec is the cause as it started this behaviour after I installed the new version of Plusspec. However the Ruby console has this:
                              Error; #<SyntaxError; (eval);1; syntax error, unexpected tIDENTIFIER, expecting end-of-input
                              su"{dire">="olosp","wssa"drol">=evsa"sagil",snec>="ea",2l_...
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `eval'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/utils_cabmaker.rbs;592;in `read_license'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/license_cabmaker.rbs;62;in `activate_license'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;240;in `activate'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `select_tool'
                              c;/users/pete/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/gkware_cabmaker/cabmaker.rbs;4523;in `block in <module;CabMaker>'
                              SketchUp;1;in `call'
                              http://www.solos-art.com
                              • G Offline
                                Garry K
                                Just an assumption bug it looks like eval has been modified. Modifying built in objects is considered bad form.
                                At this moment I suggest that you disable Plus Spec and try again and see what happens.
                                • soloS Offline
                                  solo
                                  I just tried Cabinet maker using SU 2014 which does not have Plusspec installed and I am getting same behaviour, must be another issue.
                                  • G Offline
                                    Garry K
                                    Pete,
                                    I've sent you a PM with my email address. We can figure this out.
                                    Garry
                                    • G Offline
                                      Garry K
                                      For support users shoul contact me via my web site.
                                      This will get through to me almost immediately and no chance of going to trash.
                                      I will then answer as quickly as possible.
                                      • G Offline
                                        Garry K
                                        A user has found a bug and I've fixed it.
                                        I will put out version 1.0.34 with the fix late tomorrow or early the next day.
                                        The bug has to do with finished panels.
                                        • aadbuildA Offline
                                          aadbuild
                                          Hi Garry i understand we have some type of clash between Plusspec and Cabinet maker? I can send you a beta version or vice versa of that helps? .
                                          I had a quick look at what you are doing and it's fantastic. Good job, sometimes it takes a tradesman to build site specific software. It looks like it would compliment what we are doing with Plusspec.
                                          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                          https://www.plusspec.com
                                          • soloS Offline
                                            solo
                                            Andrew.
                                            Figured out it has nothing to do with Plusspec, just a coincidental timing thing. It has to do with my login.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
