    Outliner selection not in Order
    11 Posts 5 Posters 1.9k Views 5 Watching
    • K Offline
      ktkoh
      Selecting an array of components from outliner and ruby returns the list NOT in the order shown in Outliner.
      This displays the comp names
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      sel.each { |e| UI.messagebox("Sel Array " + e.definition.name.to_s)}
      I tried sorting but either of these show error no method for sort.
      sel.sort!
      sel.sort! { |e| e.definition.name }
      I need the list of entities but sorted by name
      Keith
        Perhaps sel.to_a.sort might work ?
        BUT, to sort the definition names [properly], I suggest you 'start at the other end' !
        names = sel.grep(Sketchup::ComponentInstance).collect{|i| i.definition.name }.sort
        that's a sorted list of selected instances' definition-names...
          driven
          names = []
          sel.each { |e| names.push(e.definition.name)}
          p names.sort
          • K Offline
            ktkoh
            That is still not the result I am looking for. I need the sel entity list (all entities are comp instances) but the entities should be in order by their def name. I can't see a way to get back to the entities from the name list. Perhaps a better way would be to sort the pages after completion. I don't know if that is possible
            thanks
            Keith
              slbaumgartner
              How about this: you need to tell sort that you want to compare the names to determine order.
              sorted = sel.grep(Sketchup;;ComponentInstance).sort {|a,b| a.name <=> b.name}
              If you want to use the definition names, just insert .definition between a,b and .name
                Once you have a list of ordered definitions 'names' you can then access them using something like this:
                defns=[]; names.each{|name| defns << model.definitions[name] }
                then you have ' defns' as an ordered list of definitions, arranged by their previously sorted names...
                πŸ˜•
                This is not, thus far, rocket-science...
                • K Offline
                  ktkoh
                  TIG It may not be rocket science but so far none of the ideas has helped me get a list of instances sorted by the component name. Now if I temp add a instance name = definition name would that make the list easier sortable?? I came to programing late in life so it is not like a second language to me and I have appreciated the forum help. I hope I have not asked too often. I do look for examples and try several ideas before I ask here.
                  Keith
                    @Keith
                    Let's start back at the beginning...
                    I now think I see what you want to do...
                    It wasn't obvious thus far...
                    Please don't be put off asking - just ask as clearly as you can.
                    You have a selected 'sub-set' of the current context's entities.
                    You want to list any instances in that selection, arranged in the order of their definition-names.
                    model=Sketchup.active_model
                    instances=model.selection.grep(Sketchup;;ComponentInstance)
                    ### an array of instances, unsorted.
                    ### Make a list of definition names
                    names=[]
                    instances.each{|i|
                      names << i.definition.name unless names.include?(i.definition.name)
                    names.sort!
                    ### an array of definition-names sorted alphabetically.
                    sorted_instances=[]
                    names.each{|name|
                      instances.dup.each{|i|
                        if i.definition.name==name
                          sorted_instances << i
                          instances.delete(i)
                    ### we now have an array of instances sorted by their definition-names alphabetically.
                    To get all instances in the active context [no selection considered], then substitute:
                    instances=model.active_entities.grep(Sketchup::ComponentInstance)
                    • Dan RathbunD Offline
                      Dan Rathbun
                      I need to point out again that Steve gave the correct answer
                      So following the last sentence (in Steve's post,) you insert the .definition into the block twice, thus:
                        a.definition.name <=> b.definition.name
                      The block uses <=>, which is the Ruby comparison method.
                      This means that the expressions on each side of the <=> must be comparable, which means that at the least, their class must define a <=> method (and might also mixin in the Comparable module.)
                      I'm not here much anymore.
                      • K Offline
                        ktkoh
                        Thanks Dan when I added definition where you suggested that code worked very well. I had been adding it in the wrong place after the instance. And I appreciated the English description of what the code was saying.
                        THANKS TO ALL THE FORUM CONTRIBUTORS THAT HAVE HELPED ME!! I seem to have the ability to imagine programs that would help speed up manual operations but using the API samples to write code is a crap shoot at best. Would have not bothered without the great help available here.
                        sorted = []
                        sorted = sel.grep(Sketchup::ComponentInstance).sort {|a,b| a.definition.name <=> b.definition.name}
                        sorted.each { |e| UI.messagebox(e.definition.name)}[/code]
                          Dan Rathbun
                          You do not need sorted = [], as grep makes a new array, then sort makes another new array.
                          Save yourself some grief. Use puts or pp output to the console, rather than UI.messagebox, for testing. ( UI.messagebox can fail silently if the C WinAPI functions do not like the string passed to them.)
